Signal bleed at master volume 0
Re: Signal bleed at master volume 0
relay OFF contact should be grounded so this resistor will not act like antenna in the air
series 100k at the input of PI is helping with blocking distortion PI/Output stage so it is ok to keep it, but in multichannel amp, maybe i will put only one at the PI input after the selection is made, and selectors direct to the MV.spsychepool wrote: ↑Fri Oct 20, 2023 5:37 am 3. Most amplifiers connect the master volume out directly to the next stage (FX loop or PI input), but amplifier circuits with a series resistance connection structure like this are also often found.
Do all amplifiers that adopt this structure have signal bleeding problems? Or is it normal for there to be no signal bleeding even if a structure like this is chosen?
Please reply.
Thank you for answer.
Since I'm tired of messing around with the board and wires multiple times, I'm going to remove the resistor and proceed if no problems arise.
