Input Grid bias on triode vs pentode
Tobyk
Post by Tobyk »
Will there be more hum when input grid leak biasing a triode vs. using a pentode?
Re: Input Grid bias on triode vs pentode
This is in the case of a preamp stage? If so, I would say since the gain is higher than a triode, hum might be more of an issue with a pentode, and some small signal pentodes are known for high hum. EF86 is one.
Tobyk
Post by Tobyk »
martin manning wrote: Sun Nov 19, 2023 2:19 pm This is in the case of a preamp stage? If so, I would say since the gain is higher than a triode, hum might be more of an issue with a pentode, and some small signal pentodes are known for high hum. EF86 is one.
Yes, for the input stage – the old school grid leak biasing method. I think I read somewhere pentodes are better hum-wise in this case because of their higher internal capacitance, thus less Miller effect.. something like that..?
The pentode's screen grid hides the plate and minimizes Miller capacitance even though the gain is higher. The result is that pentodes do not suffer from high frequency roll-off like triodes do, and make better RF amplifiers.
