Stable AC Voltages For Testing?
I don’t know what I’m up against. Our whole area is like this but our household AC voltage fluctuates from 117v to 124v. Sometimes, I’ve seen in a span of 15 seconds, the voltage fluctuate from 120 to 123 and then back down to 120 or less. It gets a little frustrating when testing amp voltages. I’m looking for a very affordable solution. Is it possible?
Greg
Re: Stable AC Voltages For Testing?
An inexpensive Variac, 1kVA, would take care of that.
It won’t stabilize the voltage automatically, but you can certainly keep things under control with you keep your eye on the voltage meter .martin manning wrote: ↑Tue Jan 30, 2024 8:13 pm An inexpensive Variac, 1kVA, would take care of that.
Even with a regulator , afaik voltage regulators that I have experienced have a threshold as high as +-5vac before they trigger an auto adjustment .
Beyond the kikisui power supplies that guys like bonamassa and angus young use , which are several thousand$ each, anyone know of any voltage regulators that actually regulate ?
Charlie
Least expensive options are: do work in the middle of the night when the grid is more stable, or stop caring about the fluctuation. I will ride my variac when biasing or writing down measurements if the grid is extra wiggly, but grids going to wiggle, so don't worry about it. Uness you live somewhere that goes high enough to cause damage, it's probably not an issue.
You need a "constant voltage transformer" or ferroresonant transformer. These things produce an AC output that is nearly fixed over the ranges you describe. They used to be cheap on ebay, but I haven't looked for a while. You need one described as "harmonic neutralized" and rated for enough power to do the work at hand. A 100W tube amp might work well on a 500W ferro.
This one looks like a relative good deal: https://www.ebay.com/itm/335044593891?h ... R-z_pserYw
750VA 120Vac out, 9A output. $50 and $40 shipping (they're heavy!)
Besides questioning one's interpretation of affordable, ha ha, this is what I caught from its product prescription: "The P-1800 AR accepts input voltages over a wide AC voltage range and transforms it to a constant output of 120V, +/- 5V."Cartman wrote: ↑Tue Jan 30, 2024 7:34 pm Furman makes one, but very affordable?
https://www.amazon.com/Furman-P-1800-AR ... B001UNPCCM
This is probably the most practical, and definitely the most least expensive solution. I've noticed that very late afternoon/early evening the AC voltages cruise along at 119 to 120 for a while.maxkracht wrote: ↑Tue Jan 30, 2024 9:57 pm Least expensive options are: do work in the middle of the night when the grid is more stable, or stop caring about the fluctuation. I will ride my variac when biasing or writing down measurements if the grid is extra wiggly, but grids going to wiggle, so don't worry about it. Uness you live somewhere that goes high enough to cause damage, it's probably not an issue.
Wow! I might just go for this. Thanks! I hope it's as simple as it looks...R.G. wrote: ↑Tue Jan 30, 2024 10:23 pm You need a "constant voltage transformer" or ferroresonant transformer. These things produce an AC output that is nearly fixed over the ranges you describe. They used to be cheap on ebay, but I haven't looked for a while. You need one described as "harmonic neutralized" and rated for enough power to do the work at hand. A 100W tube amp might work well on a 500W ferro.
Greg
You're right Martin. It does one thing only - it takes in AC power on the primary side with a wide variation of voltages and produces an AC output with a small range of voltages. Depending on the design of the CVT, it may be able to take in 90-130Vac and turn it into 120Vac +/- 5% to 10%.
Variacs take in some voltage from the AC mains and convert it to any voltage between 0 (-ish) to a bit higher than the input voltage.
I've always thought of CVTs and variacs as complementary - one makes a mostly constant AC voltage, the other lets you vary the AC voltage over a very wide range.
A heavy one trick pony at that. 50 lbs? Maybe 70 lbs? Ouch!martin manning wrote: ↑Wed Jan 31, 2024 2:37 amOTOH, it's a one trick pony, where a Variac has many uses.
A variac is starting to sound like a decent compromise. Most of our AC voltages hover above 120, rather than below 120. More research…WhopperPlate wrote: ↑Tue Jan 30, 2024 8:51 pmIt won’t stabilize the voltage automatically, but you can certainly keep things under control with you keep your eye on the voltage meter .martin manning wrote: ↑Tue Jan 30, 2024 8:13 pm An inexpensive Variac, 1kVA, would take care of that.
Greg
Anybody’s thoughts on this China-made variac out of Arizona with free shipping?
https://www.circuitspecialists.com/tdgc ... 47c6d56d2c
Greg
A 10A would be big enough, and much cheaper.
Yeah, you’re right, but the next step down from this particular vendor is 5A! The deal is decent considering the shipping is included with the price you see. And I like the LCD that shows voltage and current at the same time. I’ll look around a bit more.
Greg
Whereas the price point is obviously worthwhile to consider in comparison to the Furman, but we are still looking at that +-5-10% … so if you want precision a variac is still necessary, which again doesn’t auto regulate, unless you can hire a guy to sit there with his eyes on a volt meter .R.G. wrote: ↑Wed Jan 31, 2024 3:27 am
My interests in this subject lie mostly within the live sound world , where fluctuating power causes the most headaches . Still the only thing I have seen that fits the bill there for precision voltage control is the kikusui power supplies . Not cheap. These are the 2000va model . They have smaller units.
https://www.google.com/search?client=sa ... =sivnmbhtz
Charlie
I just pulled the trigger on an old school Staco 3PN1010 in decent condition. The title of the Ebay ad was goofed up:
https://www.ebay.com/itm/305369048146
Greg
