I have a JTM45 clone built by Trinity. Everyting seems up to original spec on the board but the amp sounds quite different from a previous clone I had.
I know the OT they used has 6K and 8K primarys. ( not sur which they used )
What was the original JTM45 Ot primaty and, would the fact that : " Trinity has the same turns ratio but is wound in a different pattern to accommodate extra taps " make that amp sound significatly different ?
THanks !
OT windings question
Re: OT windings question
steel core laminations have big influence on sound, also if the winding is the same.. so 2 transformers cannot be the same if the winding is the same and laminations are not the same type.. then you change also winding type... you can have big difference
What sould be theplate voltageon the Ktt6 in a JTM45 clone ?
There is an old hand-drawn schematic that shows 440 VDC.
Winding pattern is huge. It's an even bigger contributor to frequency response than laminations and primary inductances.
And that is assuming that nothing, not a single component connection or tolerance add-up is different.
My understanding is that JTM45 originally had 8k primary (which is too high), and then went to 6k6.hebaton wrote: ↑Fri Feb 02, 2024 1:43 pmI know the OT they used has 6K and 8K primarys. ( not sur which they used )
I think it was the other way around, the first year or 2’s production used the RS DeLuxe wired for 6k6 primary and 15 ohm secondary, then went to Drake 784-103, which was just under 8k primary, 8 and 16ohm secondary.martin manning wrote: ↑Fri Feb 02, 2024 4:13 pmMy understanding is that JTM45 originally had 8k primary (which is too high), and then went to 6k6.hebaton wrote: ↑Fri Feb 02, 2024 1:43 pmI know the OT they used has 6K and 8K primarys. ( not sur which they used )
Marshall database -
http://marstran.com/Historic%20Data%20Base.htm
Original schematic with voltage chart https://el34world.com/charts/Schematics ... ad_45w.pdf
Bear in mind JTM45 was a range, with guitar, bass, organ and PA models, all with different tone shaping
https://el34world.com/charts/Schematics ... pa_45w.pdf
http://raw-sewage.net/images/jtm45.jpg
THanks Everyone,
That's the info I needed.
