Good Mods for Harp Amp Designs
Magnatron
Post by Magnatron »
I would like to build a new amp based on the 5E3 or Princeton design that is more geared toward harp use. Harp has some special challenges from the standard guitar circuit designs. The popular purpose-built amps lean toward the bass frequencies without being boomy or flabby, and generally have lower gain preamp tubes as the mics drive to feedback pretty quick. These mics can be dynamic, controlled reluctance, or crystal. The amps in most cases outside of the Bassman size are generally 5-20 watts driving 10" speakers.
What circuit design mods would be recommended to build a harp-purposed amp?
Reeltarded
Re: Good Mods for Harp Amp Designs
Post by Reeltarded »
Fairly stock with a large treble cap to dump more range. If it is muddy, a smaller and smaller early stage coupling cap. This can depend on speaker as much as anything. Celestions get your target bandpass without doing anything to a 5e3.
What mic do you really like? SM57 with boiled out transformer and blocked vents makes a virtual SM7 with good rejection and lower output. It is a good and cheap choice and maybe even the best depending on player's technique. You can over-blow the living shit out of it and gain the amp more without surprise feedback explosions.
Magnatron
Post by Magnatron »
Reeltarded wrote: Wed Apr 03, 2024 6:10 pm Fairly stock with a large treble cap to dump more range. If it is muddy, a smaller and smaller early stage coupling cap. This can depend on speaker as much as anything. Celestions get your target bandpass without doing anything to a 5e3.
My current mic is a BlowsMeAway Bulletini, which uses a dynamic element with some special tweaks. I've talked to folks with Fender Deluxes and they don't seem to like the amp for harp. Too shrill is the most prevalent comment. I really like that amp for guitar though, but hoped to use the dirt it's known for with a harp. I've been partial to Weber speakers in my other builds. I have a couple of purpose built harp amps now -- a Windy City Plus and a Harpgear -- but wanted to try my hand at building one myself.
If you haven't seen it, in this newsgroup archive there is a link to Gerald Webber's harp amp recommendations (link still works) and some comments on them.
https://alt.music.harmonica.narkive.com ... s-for-harp
