What five tools have helped
What five tools ( perhaps beyond the usual ones, temp controlled iron, nut drivers, etc ) have made a difference in your building techniques.
Re: What five tools have helped
Hemostats... great for hard to reach places!
Andy
Andy
Chop sticksangelodp wrote:What five tools...
Dental mirror
Step drills
Air-powered file
Beginner's luck
Homework (pre-build planning) Oops That's six
Tim
- FUCHSAUDIO
Torches, body grinder, English wheel, shot bag, Bridgeport.
Thermal Wire Stripper ($35 on Ebay)
Drill press
Amp cradle
Variac.
Drill press
Amp cradle
Variac.
- sportster4eva
Dovetail Jigangelodp wrote:What five tools ( perhaps beyond the usual ones, temp controlled iron, nut drivers, etc ) have made a difference in your building techniques.
Air Stapler
Circle cutting jig
Drill press
Vega rip fence
Common Sense .... (honorable mention)
Sometimes I'm good, then I'm bad..
a good bench light
long florist pliers (rubber covered handles)
steel sponge (tip cleaner, doesn't vary the temp)
a clean bench
better than ok ventilation
a clean bench
lazymaryamps
Any of you guys use one of those things that sucks the solder fumes away from you and filters it?
Can't be good to breathe that stuff (lead) for extended periods.
Maybe that should be #1sportster4eva wrote: ...Common Sense .... (honorable mention)
Now you're steppin' on toesAndy Le Blanc wrote: ...a clean bench...
Tim
you can build a cheapskate version. Just get some filters (for a manufactured version fume filter) and a fan and a power supply (AC adaptor, etc.). Doesn't get 100% of the fumes but it's a lot better than nothing.Structo wrote:Any of you guys use one of those things that sucks the solder fumes away from you and filters it?
Dental pick, I use em to bend leads to form around turrets
long nose pliers
good wire cutters
heat sinks
fans for extracting fumes
long nose pliers
good wire cutters
heat sinks
curved needle nose pliers
dental pick (good for hooking wire when desoldering)
strong lighting
full scale layouts (glue stick to work, drill, soak to remove)
good ears!
strong lighting
good ears!
Small boxer type fan in a small box with fuse and switch. Good for blowing fumes or cooling amps while running them at full power.
Thermal wire stripper. Great for use on teflon wire. Remove the insulation without nicking the wire.
Needle nose pliers with smooth jaws. They don't leave marks on wires.
Strain relief pliers. Get those darn things in and out with ease. Not cheap.
Small variac to run soldering iron(s).
