This is hopefully my next project, using Rocket transformers from Toneslut. Could you guys please take a look at my schem and layout?
It got two preamp channels, Top Boost and EF86, Vox AC30 power amp and Princeton Reverb tremolo. The boost on the first stage of each preamp is taken from Brown Note Voxy experimental layout. The same switch will be used for both preamps. The master volume will have a switch to defeat it. I guess I could put the two secondaries on the toneslut PT on a switch for a "power scaled" version of the amp.
My main concerns are the grounds and the tremolo lead dress. I guess the pots are better off on the back panel, next to the tremolo switch. Any opinions?
Vox AC30 Layout - Help needed
