Amp Cradles: make one or buy one?
C Moore
Post by C Moore »
Do you guys make your own; do you want to share some pictures? My dilemma is that I would have to buy some decent fur, birch, poplar, or even some ply might work. I would need to make it adjustable, would need some type of rubber feet and rubber strips where chassis meets cradle. Would need to buy some hardware but not much. I do not have much in the way of "woodworking" tools. I just have a circular saw and a hand saw. No chop saw, dove tail, chisel or router. But maybe I am making this seem harder than it is. What do you guys think.
Thank You
da Geezer
Simple amp cradles
Post by da Geezer »
They can be as simple (or elaborate) as you wish.....here's an example of extremely simple, which seems to be what you are looking for(?)>>>>>
http://www.el34world.com/Hoffman/tools.htm
gahult
Re: Amp Cradles: make one or buy one?
Post by gahult »
Here is one I threw together.
Gary
In the 60's people took acid to make the world weird. Now the world is weird , and they take Prozac to make it normal.
Ron Worley
Post by Ron Worley »
Here's the one I built for myself- very similar to the DST Engineering unit that I think Ted Weber now sells.....
Mine has Lazy Susan bearing assemblies on each end that allow me to rotate the amp to the working angle I want.
Ron
Nice Ron.
Do you just squeeze it tight between the arms to hold the chassis in place?
C Moore
Post by C Moore »
Hey -
Thanks for the replies and pictures. The cradle with the pivoting ends would be real nice when you are working on components that are mounted on the chassis sides (pots, jacks, etc.)
Thanks Again
Ron Worley
Tom-
There's 2 support brackets that are mounted to the bearing assemblies- they have an L shaped "shelf' that the chassis rests on.
It does not work as it's constructed with the TW- the trannies are located too close to the edge and the amp can't rest on the "shelf"- I will need to mod it. I built it when I was doing virtually all Fender amp work, and it's great for their chassis.....
Ron
rvf263
Post by rvf263 »
I saw this older thread about Amp Cradles and thought I'd post a set of plans for one that I'm getting ready to build.
Seems pretty cool.
Enjoy!
Just click on the link and download it!
http://www.mediafire.com/file/qmam43tan ... _-_1.1.pdf
RvF
Yes, that is a good way to build the cradle.
I have those same plans.
Make sure to have the arms so the amp chassis is back a ways from the center line of the cradle.
When I first built mine the whole works wanted to flip over because of the uneven weight distribution due to the transformers.
So I made two more arms, longer and further back on the end with the stops.
Also make sure it is tall enough so you can put a chassis with tubes in it that hang down and don't hit anything. :wink:
David Root
Amp Cradle
Post by David Root »
I recently bought one from Trinity Amps in Toronto. I don't have enough time to build amps, let alone amp cradles. This is very similar to those above, made of basswood.
Hmmmm, booze + electricity = :shock: :lol:
Sonny ReVerb
Post by Sonny ReVerb »
There have been several threads about cradles:
http://ampgarage.com/forum/viewtopic.php?t=7592
http://ampgarage.com/forum/viewtopic.php?t=8688
http://ampgarage.com/forum/viewtopic.php?t=4420
David Root, I've got the same soldering iron you have in your pic. I've been happy with it. Do you like yours?
"The blues is the roots, the rest is the fruits." - Willie Dixon
Wayne
Post by Wayne »
Structo wrote:Hmmmm, booze + electricity = :shock: :lol:
I'm sure the bottle is only there to help us judge scale correctly :D
David Root
Brandy bottle.
That is my very elegant way of getting water to the pad on the soldering station! The dispenser makes it very easy and doesn't drip. (The brandy was nice while it lasted though!).
Yes I like those bloo Wellers, I have two of them, the other one is on my other small bench.
Sonny ReVerb
David Root wrote:That is my very elegant way of getting water to the pad on the soldering station! The dispenser makes it very easy and doesn't drip.
Ingenuous!
