Tube Dampers for EF86
Hello all,
I'm planning my next build. Looking at using an EF86. Any recommendation for tube dampers?
Anyone ever use this... http://thetubestore.com/eat-cooldamper.html
Thanks!
-Ferdie
Thanks!
-Ferdie
Re: Tube Dampers for EF86
I haven't delt with these exact dampers but dampers do help in certain situations mostly hi fi audio.
But not for $35 if you really think you need them check out the weber speaker amp parts page and buy a vibration ring for under a dollar and just make sure the amp has ventilation to cool. i.e. don't throw a packing blanket over it in the desert at high noon while you play at "11".
My Daughter Build Stone Henge
I just ran across this at 18watt.com. It was drawn by Heink at HBamps.
http://www.18watt.com/files/ef86_quiet.pdf
You can also use silicone o-rings for fuel injectors. I can't remember the size,tho. You can buy them at AutoZone.
LeeMo
LeeMo
I bought a pair of shoes from a drug dealer the other day. I dunno what he laced them with but I’ve been tripping all day,
You can also take an 1-1/4" piece of heat shrink tube, dia larger than the dia of the tube, and shrink it onto the top 1/2 of the tube.
I have been using heat shrink for years. I found it works even better than the o rings and cheaper.
A while ago, I built an AC-15-ish amp with an EF86 channel only. The amp was squeeling a bit, and I was sure it was due to EF86 microphinics. So I bought other EF86's, even Cryo treated ones. And I bought tube dampers. And nothing helped. Then, I did what I should have done in the first place - I went looking for the oscillation, and solved it at the source. And now the amp is fine, with or without the damper. So the moral of the story is : don't even worry about dampers until you know you actually need them.
Good luck!
Good luck!
sliberty wrote:A while ago, I built an AC-15-ish amp with an EF86 channel only. The amp was squeeling a bit, and I was sure it was due to EF86 microphinics. So I bought other EF86's, even Cryo treated ones. And I bought tube dampers. And nothing helped. Then, I did what I should have done in the first place - I went looking for the oscillation, and solved it at the source. And now the amp is fine, with or without the damper. So the moral of the story is : don't even worry about dampers until you know you actually need them.
Good luck!
Make sense to me.
Thanks all. I will try it without dampers 1st. It looks like I have several more affordable options if I do end up having issues.
Anyone have a recommended ID for o-rings so there not too loose or too hard to put on? (There's no convenient O-ring store next the Radio Shack)
When I bought mine, I got them from :
http://herbiesaudiolab.home.att.net/
He makese several different types, so you might want to email before ordering. They are very easy to put on and to remove.
Steve
Steve
http://stores.ebay.com/sandyphotos-Vacu ... idZ2QQtZkm
I use these on all my builds and most of my amps on the preamp tubes. Work great. I even use the EL34 ones in my Express Combo.
I bought some of those from Sandy's photo.
They seemed to help the EL84's in my Belair combo.
The only bad thing about them is if it is a tubes down amp, you can't use the wire tube retainers with the O rings installed.
I should try the Heat Shrink. That doesn't make them run too hot huh?
And does it give off any type of burning plastic smell?
The Heat shrink does not give off any burning smell. It is designed for high heat. Also, I have been using it for years without any problems. I have it on all the PI and driver tubes in my Conrad Johnson 11a for 4 + years no problems and sounds great.
I first saw them on Mesa Boogie 12ax7's in the 80's . I regularly use it on my V1 tube in high gain amps with out any problems.
Conrad Johnson uses the O-ring dampers in their preamp, but I switched tubes out so much ( to find the Holy Grail) . I ended up with Heat shrink on all the preamp tubes and it works as well if not better than O-rings. a fraction of the cost. you can even use BOTH !
Tubes have no problem with heat, shrink tube is the best, and costs nothing-
If you choose to use heatshrink make sure it's not the adhesive type!!!
