Where to get circuit board meterial?
austinb
Post by austinb »
Where is the best place to get circuit board material? FR-4 without any copper clad to use with eyelets and binding post? Fish paper like used with old fender amps?
mcrracer
Re: Where to get circuit board meterial?
Post by mcrracer »
Mcmaster-Carr has several different grades of Garolite. Different sizes also, 1/16 and 1/8 inches thick. I think the prices are great.
markr14850
Post by markr14850 »
Just don't buy the black FR4. I'm having a problem with it being conductive.
austinb
Post by austinb »
Mcmaster-Carr has a $250.00 minumum order.
markr14850
I have a $35 order from them arriving today.
mcrracer
Post by mcrracer »
I just placed a $30. order with MC last week. The Garolite was delivered the next day. They did not mention anything about a minimum order.
austinb
Post by austinb »
This Garolite is a plastic. Wouldn't it be better to use fiberglass? I am thinking about making my own using fiberglass resin and fiberglass cloth sandwished between 2 pieces of glass with pennys around the edges to control the thickness. It would be very inexpensive. Then use brass eyelets like used in women's belts for the solder eyelets. What do you think?
austinb
Post by austinb »
Talking about a scratch build LOL
jaysg
Post by jaysg »
austinb wrote:This Garolite is a plastic.
You must be looking at the wrong stuff. Garolite G10/FR4 is fiberglass.
It's kind of a pain to cut, unless you have a bench cutter or bandsaw. You can buy pre-cut pieces from a number of people like Ken Watts at turretboards.com
markr14850
Life is short. If laying up GRP makes you happy, do it.
For me, it just makes me itch.
gearhead
Post by gearhead »
jaysg wrote: It's kind of a pain to cut, unless you have a bench cutter or bandsaw. You can buy pre-cut pieces from a number of people like Ken Watts at turretboards.com
I use a tile cutter (wet). Cheapy portable unit works great, with no airborn glass dust.
Now, drilling is a different matter.
sliberty
Post by sliberty »
I bought a supply of board material from McMaster Carr a while back, and it is great stuff. They have many different types. And they deliver faster (in NJ) than I have ever seen!
AustinB
If you are going to go the McGyver route then go to the local dump and cut up some material from an old fiberglass bath tub or shower stall and use that. :?
My suggestion is just get some material from a supplier. There are so many people selling the stuff you have many sources. I get mine from Turretboards.com but you have options.
Cygnus X1
Post by Cygnus X1 »
How about Lexan?
I just bought a small sheet to play with.
If it can take the heat, then I think a clear lexan board would look very unique.
Not sure about that but solder flux and burn marks won't be very attractive.
