Watch out for these as I just had a issue with a customer who after purchasing a set stated that the Neck pick up was open, well these have a built in cap to roll off some lows so you can not do a resistance test to confirm the pickups integrity!
He sent it back, I hooked it up and it works fine!
I sent him a email about how the pickup is made along with another pretested set just for good measure and his A hole tech says that this Neck pickup is open also.
To make matters worse this so called tech tells me the pick up is shorted and his reading is well over 100k ohms! Yeah your a tech alright!
Duncan invader neck pickups
