Tweed super to tweed deluxe conversion
Have a tweed super, but would like to go to a tweed deluxe w/6V6`s, anyone have a line on maybe a bracket to convert to the smaller power tranny? Really appreciate the help!
jim@Omegaamps
jim@Omegaamps
Re: Tweed super to tweed deluxe conversion
Hi Jim,
My buddy just picked up a 56 tweed super chassis that runs 6v6's stock. They came that way back then (6v6's or 6L6)..they just used a washers between the nuts to catch the edge of the cut out..if that makes sense.(pt)
One question though, If this is a real tweed super? why not sell it, and buy a real tweed deluxe? put the change in the bank
Chris
Chris
I guess that was 2 questions..
super
Its not an original, i`ve played a 56 tweed deluxe.. n man, oh man, i`ve gotta get that fig out!Chris G wrote:Hi Jim,
Chris
super
Thank you for the advice!Chris G wrote:I guess that was 2 questions..
jim
I have a gut shot here I'll post it up later
here are those guts/chassis
What model super is it? What are the voltages now? What about just dropping the voltage with some Zener diodes on the center tap of the b+ secondary. So you can run 6v6's. 400v minus would be good. Cathode biased.
Most supers are fixed biased. And a different tone circuit.
You might be able to sub in a 5y3 and get there.
The super OT might be a bit low in the primary impedance.
Tweed deluxed were about 8k, but I find 6k sounds great.
super
5E4 I wanta get it right....using the parts n all..thank you for advice! Really appreciate it! THe voltages are high, he used a weber vst bassman, it blew, i installed a 70`s bandmaster, w/diodes...same thing, i want it to get creamy like the originals do..billyz wrote:What model super is it? What are the voltages now? What about just dropping the voltage with some Zener diodes on the center tap of the b+ secondary. So you can run 6v6's. 400v minus would be good. Cathode biased.
super
Thank you so much!Chris G wrote:here are those guts/chassis
jim
Jim, I built a 6V6 super changed the baffle to 12"
used a black face Deluxe PT from Mojo. Mercury magnetic OPT
At the end of the day ended up using a known Hendrix JTM 45-100
preamp a Dumble phase inverter and a black face deluxe power amp
set bias due to the fact most of the clubs we play the electrical is messed up
Steve.
Steve.
super
AWSM! Def hip to the dumble driver thingy! I appreciate your input! I`l get ta this project soon!67plexi wrote:Jim, I built a 6V6 super changed the baffle to 12"
Steve.
My best, jim
