yesWith your suggestion, does the LED alone intensify the effect? Like this?
Princeton Reverb and Adjustable NFB placement/routing
Re: Princeton Reverb and Adjustable NFB placement/routing
Excellent, thank you guys!
Just plug it in, man.
The Princeton Reverb Trem is a bias vary system. If the bias is too hot, you will get weak tremelo. Before you rewire the whole amp, check your bias and adjust as necessary. One of the best mods for a Princeton Reverb is the addition of a bias adjust pot.
Use your head.
Thanks, Paul. I'm going to try the LED on my next Princeton.
