after rebuilding two, the noise decreased significantlymartin manning wrote: ↑Thu Jun 09, 2022 10:32 am It's not just the ripple voltage; decoupling of the stages is also important. The last filter is powering no less than six triodes, where two or at most three is usually considered the best practice. It's not quite as bad as it seems, though. Typically only one channel is in use at a time, so the worst case is it supplies four active triodes, and the phase relationship of the reverb recover stage to the others is all over the map. I find there are no issues with the one I built, and in fact the original circuit design and layout, random grounding and all, has been working pretty well for almost 60 years :^)
AB763 grounding scheme
Re: AB763 grounding scheme
www.myspace.com/20bonesband
www.myspace.com/prostitutes
4x12" w/H75s
4x12" w/H75s
I rebuilt the grounding and power supply, using merlin as a guide. One filter cap per preamp tubemartin manning wrote: ↑Thu Jun 09, 2022 2:36 pmRebuilt how? What changes were made wrt the original?
4x12" w/H75s
4x12" w/H75s
Could you be a bit more specific?Roe wrote: ↑Thu Jun 09, 2022 4:21 pmI rebuilt the grounding and power supply, using merlin as a guide. One filter cap per preamp tubemartin manning wrote: ↑Thu Jun 09, 2022 2:36 pmRebuilt how? What changes were made wrt the original?
I can't help with the specific details as they pertain to rebuilding an AB763, but I'll second Roe's recommendation to read Merlin's grounding advice. He made the Grounding chapter of his his book about preamps downloadable completely free on his website.
http://valvewizard.co.uk/Grounding.html
This is a really easy follow explanation of where the current flows in the ground path, and why micro-managing current flow is important.
use multi-star grounding as defined by MERlin the tube wizard. see the excellent post aboveOddvar R wrote: ↑Sat Jun 11, 2022 11:14 amCould you be a bit more specific?Roe wrote: ↑Thu Jun 09, 2022 4:21 pmI rebuilt the grounding and power supply, using merlin as a guide. One filter cap per preamp tubemartin manning wrote: ↑Thu Jun 09, 2022 2:36 pm
4x12" w/H75s
4x12" w/H75s
moreover on this tip that every node must to have el.capacitor close to the valve which is supplying, it is a good habbit to think about plastic chassis. or how you can make amp in plastic chassis without humm . then if you do so, ground the amp close to input jack in one point and all is done.
Hi,
I am the original poster, and I wanted to say thanks to all the contributors. The Grounding chapter a couple of posts up is a great find! Lots of excellent information there. My kit has made it to Australia, so it should only be a week or so until I have it in my hot little hands. I like the ideas and info posted. I will make a decision on which way to go with the build, and let you know how I go. Cheers all!
