Brownface Potentiometers
Re: Brownface Potentiometers
V7 pin 3 - 446v
pin 4 - 451v
pin 5 - -49.3v
pin 8 - 25.2mv
V8 pin 3 - 446.3v
pin 4 - 453v
pin 5 - -49.6v
pin 8 - 26.2mv
I also have 1k5 grid stoppers on pin 5 of the power tubes.
I also swapped the output transformer leads to no avail.
pin 4 - 451v
pin 5 - -49.3v
pin 8 - 25.2mv
V8 pin 3 - 446.3v
pin 4 - 453v
pin 5 - -49.6v
pin 8 - 26.2mv
With only 25 mA (assuming you have grounded the cathodes through 1 ohm resistors) your bias is very cold, only 11W. It should be more like 18W, Vpin3 x Vpin8.
Sorry Martin have got a pair of 6p3s-e tubes in not 6l6 i just use them for starting an amp up.
I see. The 5881 on the schematic are 23W tubes anyway, so I should have suggested 14W dissipation. 6p3s-e are listed a 20W, so things look reasonable.
Changed tubes to JJ 6L6 and rebiased signal on pin 5 with grid stopper is fine but pin 3 is horrible loud and distorted and sounds out of tune is this looking like the output transformer?
Could be. Do you have another one to sub in?
As it happens yes i do same transformer from same supplier
https://modulusamplification.com/f-styl ... 3295-p.asp
Will have to wait start my shift pattern tomorrow night.
Just tested the output transformer primaries resistance to the b+ winding 183 ohms on V7 and 88.2 ohms on V8 then tried both primaries to ground both read well over 1m and it just carried on going up, then tried 8 ohm tap to primaries 1m and still going. 8 ohm tap to ground 2.3ohms.
That seems to indicate shorted primary turns. The resistances should be much closer than that.
Thats what i thought too ,brand new transformer too
How does the other one measure?
more or less exactly the same
It would be pretty strange to have two defective ones. You could try the "super secret transformer test" if you have a neon bulb: https://www.premierguitar.com/the-super ... mer-tester
Some discussion on that here: https://ampgarage.com/forum/viewtopic.php?f=6&t=35771
Thanks Martin will have a look when I get home from work tomorrow
Just tried the resistance between the blue( 183) and brown (88) and got 97 ohms, I wonder if the colours are the wrong way round. What's easiest way to find the correct b+ wire?
