Amplifier Power Regulator or Voltage Regulator question
Fender Amp Discussion
Toppscore
Post by Toppscore »
Anybody use and recommend power regulators that'll manage
to lower typical 120v power from home wall circuit outputs
or bar/club/hall power outputs?
I'd like to get my vintage amps' power down to the 110v
that they are designed for. Also, a quality regulator
that I can visually see the settings.
I have two rackmount Furman six plug line conditioners, but I believe
they are more for surge, spike and brown-out management
power conditioners ~ rather than voltage regulators.
Any good product recommendations you like?
Fan of Fender Trainwreck Dumble
rock_mumbles
Re: Amplifier Power Regulator or Voltage Regulator question
Post by rock_mumbles »
There's no regulator involved but the geofex vintage AC adapter lowers the voltage to the amp ???
http://www.geofex.com/Article_Folders/v ... ntvolt.htm
Toppscore
Post by Toppscore »
rock_mumbles wrote:There's no regulator involved but the geofex vintage AC adapter lowers the voltage to the amp? http://www.geofex.com/Article_Folders/v ... ntvolt.htm
Hi, Rock! Thanks.
I am looking for a device that will sit between a wall power source
and my amplifier(s). Similar to a pedal footswitch, but only with
controls to lower are raise the input voltage for my vintage amps.
Just want to protect the electronic components better.
And, know that I am doing it.
Thanks again. Toppscore :wink:
Dr-Joned
Post by Dr-Joned »
I have seen some manufacturers like APC, Furman or others that have a real time conditioner. I found one once upon a time that would allow you to set the voltage within a given range. It would be great for those older vintage amps.
I Think I Think Too Much !
Bob S
Post by Bob S »
There are other ways, but I think a simple variac with a voltage meter will suit your needs.
As long as it has the current capabilities.
Why Aye Man
Reeltarded
Post by Reeltarded »
Totally agree with that. Easy. Simple. Purposed. :)
Toppscore
Post by Toppscore »
Bob S wrote:There are other ways, but I think a simple variac with a voltage meter will suit your needs. As long as it has the current
capabilities.
Bob S. Thanks. Yes. A variac type device with a voltage meter display
to accurately discern the current output voltage . . . . . and a manual variable
voltage control from 100v to 130v is perfect for me.
I'd a long discussion with a variac manufacturer/reseller today.
Apparently, there's more to consider regarding "amp output" from variacs
and voltage regulators; along with the line voltage output towards
both the vintage amplifier and towards the variac.
Does anyone know of or has purchased from: David Riddle?
Big time EBay seller with over 11,000 positive feedbacks?
David Riddle Company
www.DavidRiddle.com
This man sells hundreds of styles of variac meters and regulators
and test equipment from $17,000(+) down to the $150-$300
level for items of interest towards my amplifiers.
Please let me know if you have purchased or experienced
the David Riddle Company for variac or test equipment type products.
Thank you. Toppscore :)
rp
Post by rp »
Something like a Furman that doesn't just condition but also lets you vary and set a regulated voltage will cost mucho big bucks and weigh mucho too. I never tried it but think all you need is that link to Geofex, better even than a Variac which don't weigh little either and can be accidentally bumped to like 140V.
Toppscore
Post by Toppscore »
rp wrote:Something like a Furman that doesn't just condition but also lets you vary and set a regulated voltage will cost mucho big bucks and weigh mucho too. I never tried it but think all you need is that link to Geofex, better even than a Variac which don't weigh little either and can be accidentally bumped to like 140V.
Thanks. I realized I have three Furmans, expensive ones.
But, one needs to add a variac type device after the Furmans
and before any devices receive dirty voltage/wattage/amperage.
Just want to get something soon. The four I'm looking at are
all between $200 and $300. I might get a heavy duty variac
for my home on a permanent basis for all expensive electronic devices;
and a lighter variac for travel and gigs.
I won't worry about someone turning the voltage up, as I don't worry
about someone throwing drinks on my amps, etc. Things happen.
Hey! ~ a valued vintage amp could blow a transformer or output tranny
or a set of capacitors or a speaker, right?
Reeltarded
The $70 are the good ones. The expensive ones die just the same, or not.
There is no "lighter" variac. It's a huge hunk of metal.
Toppscore
Post by Toppscore »
Reeltarded wrote:The $70 are the good ones. The expensive ones die just the same, or not.
What do you consider tje Amp Maniac and the Tone Preserver?
Are they variacs?
They are light.
I noticed a 30 pound variac for home voltage regulation
that would be perfect for valuable home equipment.
No biggie about the weight, as it would stay in my music room.
But, I want another lighter variac type to take to practice
or an event. Strongly thinking about the Amp Maniac.
But, still investigating and very interested at all the great comments.
Toppscore
Post by Toppscore »
Reeltarded wrote:The $70 are the good ones. The expensive ones die just the same, or not. There is no "lighter" variac. It's a huge hunk of metal.
Which variacs are "$70". PLMK.
Thanks. Toppscore
Reeltarded
They look like this and they are 10 amp rated. The meter is out to lunch or never works.
Toppscore
Post by Toppscore »
Have you seen the Tone Preserver or the Amp Maniac?
Following are three I like, as well as the Amp Manic:
http://www.ebay.com/itm/380453842256?ss ... 1438.l2649
http://www.ebay.com/itm/110542427997?ss ... 1438.l2649
http://www.ebay.com/itm/111000907515?ss ... 1438.l2649
Reeltarded
I like the red one.
