I looked at the schematics of the two amps to get the voltages, the Bassman being a 6L6 amp had higher voltages than needed for 6V6's so I took a look at the Deluxe reverb for guidance. Then I got to thinking (always a dangerous thing) since I will be using two switches to go between amps I wondered what I would get with the output at a higher voltage and fixed bias but with the 5E3 input and phase inverter. Taking it one step further, what if I had a three position switch (rather than the first two position) and I stick a BF tone stack in between the 5E3 input gain stages which are now in series? Lost anyone yet?
Other than the input tube being a 12AY7 I pretty much have a Princeton Reverb. Started drawing it up and it seems feasible, the question though is whether it would be worth while? It will probably be as complicated an amp that I could make. I know the 5E3 and the Bassman circuits will sound different but would the Princeton give me much more than if I just added reverb to the Bassman? I don't know. I could do a prototype with just the two and try it I guess.
I think this is mostly correct. Left out the reverb circuitry (actually haven't done it yet), makes the schematic look less busy. So I have a 6 pole 3 position rotary switch (SW1) that does the majority of the switching. SW2 does the voltage dropping for the 5E3 and shorts out the NFB that the Princeton would have. Of course would have to adjust some resistors to taste.
So in case the above does not complexly make sense, a Tweed Deluxe, a Princeton Reverb (with the lower gain 12AY7 instead of a 12AX7), and a 6V6 powered 57 Bassman. Or just the 5E3 and the 5F6a with reverb? Or have I already lost it?
[img
