Mods for improving 5E5-A tone stack?
Built myself a SE amp awhile back with a 5E5-A inspired tone stack. The amp sounds great but the Treble & Bass add volume as well as breakup when turned up, which I can live with, but when each control is turned down the respective Treble & Bass frequencies become muffled.
I tried a 5F6-A Bassman style tone stack TMB which solved the muffled frequencies as well as the volume boost thing but the overall amp magique has been lost.
I am contemplating returning to the original 5E5-A style tone stack but before I do I was wondering if anyone might have some suggestions on improving or mitigating the tone stack quirks?
Re: Mods for improving 5E5-A tone stack?
Might try lifting the 5 meg feedback resistor around V2.
I like to disconnect the 220k To ground as well, but then youll have alot more gain !
Here is a mod for improving the tone stack - but not mitigating the quirks.
I have build a 5F4 super and didnt like the scooped mid in the design, which sounds more like blackface than (Champ or Deluxe) tweed
So I have put a switch, between V2 and V3, on the bottom of the chassis, with a 680pf cap. This allows me to up the standard 250pf on the treble pot, from 250pf to 930pf.
This warms up the middle tremendously.
Hey Billyz,Might try lifting the 5 meg feedback resistor around V2.
Will eliminating the 5meg & 220k series resistors to ground change the response of the Treble & Bass controls, improving the clarity in the counterclockwise rotation?
With those resistors in place the amp has plenty of gain.
I was running it without any negative feedback - sounded best!
I am also utilizing one output from an LTPPI, as in the Gulsekt-88 and with help & guidance from MattH, which has given this amp a BIG amp sound.
It has slightly greater output (volume) than my '65 Reverberocket (2-7591A's in PP), as big a frequency response, but much better harmonic content, overdrive characteristics, and touch sensitivity.
Very impressive as far as I am concerned.
My only niggling issue is the response of the tone controls.
When playing I just set the controls to 12 noon and make all my adjustments from my guitar. Great!
However, like many DIY'ers, I can't leave well enough alone - must keep tweakin' & improvin' whenever possible.
Thanks BFMB - I will definitely play with that!So I have put a switch, between V2 and V3, on the bottom of the chassis, with a 680pf cap. This allows me to up the standard 250pf on the treble pot, from 250pf to 930pf.
(deleted)
Hey Matt!
When originally voicing this amp I was concerned with getting the most clean headroom/highest volume level before breakup out of it.
The idea was that I could get earlier breakup with the use of a 6V6 then increasing headroom incrementally up with 5881, 6L6, EL34, KT-77, etc.
Ya' know - a good range of output and flavors to shift to while on the fly(cathode biased).
However...
After playing with all those different output tubes I whittled it down to 6L6, EL34, & KT-77.
I found that the JJ KT-77 had the best of all worlds - great cleans and outstanding overdriven tones.
I was using a 500ohm 10watt Cathode resistor/1K 5watt Screen Grid resistor with about somewhere between 360-370V on the Anode (have to check my notes) with a 5U4GB rectifier (sounded best).
I will be installing a VVR controlling voltage only to the output tube to simulate 5Y3. Further voltage drop will be in lieu of a Master Volume control.
I had tried a Presence control off the LTPPI but found that at best it had little effect so I dropped it.
I played with multiple different values of NFB: 100k, 82K, 56K, 33K, etc. while trying to achieve max headroom, but found that despite losing a little in the headroom department the overall response of the amp sounded outstanding with no NFB.
I came to the realization then that I was probably asking TOO much of the design and that tone and response was way more important than clean headroom.
I could achieve that in copying this format into a Push-Pull amp.
So...
Back to your suggestion:
What would the parallel 5M achieve? And with what value NFB resistor?
However...
So...
I've got both a 4.7M as well as a 5.1M available.Rather than yanking the NFB loop, you may actually want to try out increasing the NFB. I know it sounds counterintuitive, but give it a whirl. If you've got a second 5M resistor kicking around, just clip it in parallel to the one already in there as a quick test.
I run those changes with the stock nfb circuit. Removing the nfb will certainly increase the gain as well. I probably would do both. Since the tone circuit is passive, your throwing away gain at those frequencies the more you roll them down.
I find the 5meg local feedback tends to squash and flatten the sound. I would think reducing the 5meg would further this affect. Everyone I have done this mod for absolutely loves it.
All I can say is try it all the ways mentioned here. There is no one right way, it all depends on what you prefer for your sound and feel. I like my amps pretty lively. Some like em smooth and refined.
(deleted)
I meant to say I would not remove both feedback loops. Cant type anymore and never could.
I got what both y'all are sayin'!
I already have a 52K Global NFB resistor hooked up from the end of the PI tail resistor to speaker jack from the 5F6-A tone stack scheme that I just removed. I'll keep that in place for now so I can see how the amp sounds with and without it after I finish rewiring for the original 5E5-A tone stack.
I wired in a 4.7M from the 2-270K resistors coming off the 2 Volume controls and connected to the end of the .1uf cap. Instead of connecting a 220K resistor from the end of the .1uf cap to ground I'll leave it out and use a jumper wire to make the ground connection.
See how that sounds, then try paralleling another 4.7M, etc.
I've almost finished rewiring but I have to stop soldering now.
I have off tomorrow and will finish up then test!![Mr. Green :mrgreen:](./images/smilies/icon_mrgreen.gif)
(deleted)
On top of that! Just eliminating the resistance not the connection to ground.Instead of connecting a 220K resistor from the end of the .1uf cap to ground I'll leave it out and use a jumper wire to make the ground connection.
OK fellas, just for clarifications sake('cause now I'm not so sure) -
I remove the 220K resistor and replace it with a jumper wire
OR
do I remove the 220K and disconnect the connection to ground at that point altogether?
OR
As Emily Latella would say "nevermind"!
Gentlemen, thanks a' plenty for all your input!
The amp she's a' singing!
After trying different combinations of the suggestions made by Billyz & MattH,
I have settled on removing the 220K resistor (improvement of the clarity in both Treble & Bass controls) as well as removing the 4.7M resistor (further improvement in clarity & an increase in gain).
Great mod Billyz!
I removed the 56K Global NFB resistor, however, I am leaning towards reinstating the GNFB with a lower amount of feedback - 82K or 100K just to rein in the wildness a tad.
BFMB - I like where the overall tone of the amp sits right now so I'll play with it for a bit before I try upping the 250pf cap on the Treble pot to say 390pf, 500pf, etc. probably over the weekend.
Thanks for that suggestion!
The amp is really great sounding now - very touch sensitive, great overdriven tones with both 6L6 & KT-77 with very musical and open cleans. The amp is always articulate clean or overdriven but because of the harmonic content it is never harsh or sterile sounding!
Me likey!
A key component to this amp sounding SO big and beyond what a SE is normally capable of is due, IMHO, to the inclusion of the LTPPI as suggested by MattH.
Kudos to you Matt!
Thanks to everyone for their input - it's what makes this forum priceless!
Great mod Billyz!
Me likey!
Kudos to you Matt!
