5E3M Deluxe Micro 1 Watt Tweed
Re: 5E3M Deluxe Micro 1 Watt Tweed
Where did this idea come from?
Surely those grounds have to connect to the pre-amp / chassis ground somewhere?Instead of grounding the center taps to the chassis they are connected to the power tube cathode resistor and first filter cap 'ground' connections
This seems a bit along the lines of Merlin's multiple star grounds arrangement?
The ' power amp floating ground' has not been implemented but now that I've looked closer I realize there is no return path for the preamp ground which attaches to the chassis at the input jack. I'll do more research and revise the schematic and layout.
I went ahead and reverted the the classic power amp grounding scheme.
[img798]http://robrobinette.com/images/Guitar/D ... _small.png[/img]
There would be a lot of silence the way it was shown before, unless the CT was getting to ground in some other way.
From the internet!martin manning wrote:Where did this idea come from?
I obviously missed a 'minor' detail in the design of the power amp floating ground, so, ah, nevermind.
Here's an updated Deluxe Micro layout:
[img882]http://robrobinette.com/images/Guitar/D ... _small.png[/img]
- dorrisant
No worries Gene!
Here's a short sound clip of Deluxe Micro #3 using a Tele's neck pickup and 12" Tester speaker:
https://www.youtube.com/watch?v=aD42Z26Ua3A
- davidjon_99
Sweet Rob. I've visited your web site several times and I'm very interested in this little amp. I'll probably build it after I finish the 5e3 I have in the queue next. BTW, I plan to do the cascaded input mod you have on your site. Thanks for putting all the time in for this and thanks especially for sharing it.robrob wrote:Here's a short sound clip of Deluxe Micro #3 using a Tele's neck pickup and 12" Tester speaker:
