79 Deluxe Reverb volume problem
Signal seems to be getting by this volume pot when it is turned down. Swapped the pot over from the first channel and the same issue . Anyone run into this issue ?
"It Happens"
Forrest Gump
Forrest Gump
Re: 79 Deluxe Reverb volume problem
#1 test the tubes.
#2 voltage chart the amp.
If you don't have a tube tester swap V-1 and V-4 12AX7
Swap the first preamp tube with the second, does the issue then move to the other channel?
Make sure the path to ground is good. I think this means its physical mount to the chassis in this case.
If it's just a little signal, that's normal. Most pots don't actually get all the the way to the ground terminal. If it's a big signal, you have a bad ground, or a bad pot.
Or a bad tube - really!
It may be not be credible until it's been personally experienced.
I'll buy that. The signal appears at cathode and plate.pdf64 wrote:Or a bad tube - really!
You never play the amp on zero anyway, so why the fuss?
- JazzGuitarGimp
When I was a teen, I had a friend who had a peavey head & cab. we'd be in his bedroom with the door closed and he'd playing his guitar. All of a sudden, his mom bursts through the door and yells "turn that thing down!" And he'd show her: "look mom, the volume control is all the way down!" - which it was. When she left the room, we both laughed because the two of us knew good and well that the guitar had a volume control too.
Lou Rossi Designs
and Schematic Capture
