Dual Showman 2x15
Dual Showman 2x15
Hi all, I'm new here. I found y'all searching for either a Dual Showman 2x15 cabinet to buy or plans to build one. I am extremely impressed that Only one or two plans seem to exist online for almost any of the Fender amps/cabs. It seems hard to believe, I"m hoping it' just me:) Any info anyone may have would be very much appreciated!
Re: Dual Showman 2x15
Instead of trying to build one you might have luck finding a used vertical 2-12" Bandmaster cabinet to mod and restore.
Because of there size not many folks want these big guys.
I have one. ( 2-12" version) and they are the same size as the Showman cabinets I believe, but have the baffle cut out for the 15" drivers.
The later versions of these cabinets even have port cut outs.
not all cabs are equal. the size of the 2x15 cabs varied somewhat. I remember doing an A/B test of two cabs, and the biggest one (45½" x 30" x 11½" (115.6 x 76.2 x 29.2 cm).) sounded the best, at least for bass.
Cf: https://www.thegearpage.net/board/index ... st-8510339
www.myspace.com/20bonesband
www.myspace.com/prostitutes
4x12" w/H75s
4x12" w/H75s
