AB763 Bandmaster Sounds Fizzy and Ratty
Fender Amp Discussion
Jake1524
Re: AB763 Bandmaster Sounds Fizzy and Ratty
Post by Jake1524 »
bepone wrote: Fri Apr 28, 2023 5:56 pm another UP just under total re-assembly and boards and wires after 50 years ARE a problem :lol: just working on it now
Looks like the board is possibly conductive? Refer to post above this!
I just noticed something else that may be relevant. When plugging my guitar in I heard an odd screeching sound. When i ground the tip to my finger, it makes noise, but not consistently. Noise attached.
https://soundcloud.com/user-47032081/in ... -squealing
Reeltarded
Post by Reeltarded »
Aha
I would hate to tell you what the easy fix is. It is replace the board, or go look at Dumble files where bepone has disassembled, baked, recoated and repaired, then reused board.
bepone
Post by bepone »
hm ok, input jacks and bad grounding, bad connection? remove them and clean oxide properly
Jake1524
Post by Jake1524 »
Reeltarded wrote: Sat Apr 29, 2023 3:39 pm Aha
I will happily replace the board if you guys feel that’s the logical solution here!! Do you know where to source a new one? Honestly a couple hours of work doesn’t seem like a big deal after all the time spent trying to diagnose this…
Jake1524
Post by Jake1524 »
bepone wrote: Sat Apr 29, 2023 3:40 pm hm ok, input jacks and bad grounding, bad connection? remove them and clean oxide properly
Is this based if the sound clip?
How do you feel about the readings I posted after probing the board? Do you feel that’s enough to verify the board is conductive?
bepone
Post by bepone »
thx :)
here is the bottom isolator board, found that on many places making shorts to the ground/ chassis
Reeltarded
Doig Hoffman probably has identical layouts premade. Might be quicker fix that way or maybe get a perf board and set your own eyelets?
Those burn-thrus need to be repaired if you reuse this set. brb
Jake1524
Post by Jake1524 »
Reeltarded wrote: Sat Apr 29, 2023 3:45 pm Doig Hoffman probably has identical layouts premade. Might be quicker fix that way or maybe get a perf board and set your own eyelets?
Hmm I would rather get something premade.. just checked out his site.. seems like a good approach.
Are the voltages I posted enough for you to diagnose a conductive board? Wouldn’t this throw off voltages somewhere else in the amp?
sluckey
Post by sluckey »
Jake1524 wrote: Sat Apr 29, 2023 1:34 pm poking around on the board yielded some spots as high of 150mv.
Not sure I would put that in the category of "conductive board". Volts or tens of volts would definitely be a problem.
Jake1524
Post by Jake1524 »
sluckey wrote: Sat Apr 29, 2023 4:22 pm
Not sure I would put that in the catagory of "conductive board". Volts or tens of volts would definitely be a problem.
Ok thanks for this. Those were my thoughts, but Ill admit i got very excited about a possible solution here!
