Silverface Fender Twin schematic
Fender Amp Discussion
plookit
Post by plookit »
Could someone help me identify the year and schematic number of this Silverface Twin. The owner wants a mod to be reversed.
Ten Over
Re: Silverface Fender Twin schematic
Post by Ten Over »
Serial number indicates 1980 which would make it a 135W model. Picture of the rear and/or picture of the guts would verify.
Ten Over
Post by Ten Over »
If this is the export model...
plookit
Post by plookit »
This is fantastic. Thanks so much. I’ll get a picture of the back. I don’t have it in my bench yet, the guy wants me to put the hum pot back in. He says it was modded out of it some time ago.
plookit
Post by plookit »
So, the task is to put back a hum pot that was removed. The amp sounds great except when the reverb is engaged and then it has a lot of hum. Any thoughts on what that might be. It’s been sitting unused for a good while.
plookit wrote: Sun Apr 30, 2023 4:43 pm So, the task is to put back a hum pot that was removed. The amp sounds great except when the reverb is engaged and then it has a lot of hum. Any thoughts on what that might be. It’s been sitting unused for a good while.
Hum pot most likely will not fix that. Does the reverb hum if the footswitch is disconnected?
plookit
Post by plookit »
No, hum goes when you disengage reverb
plookit wrote: Sun Apr 30, 2023 6:41 pm No, hum goes when you disengage reverb
Guess I need to be more specific. Unplug the two RCA phono plugs from the RCA phono jacks on the back of the amp. Turn the reverb pot up. Does the amp hum?
plookit
Post by plookit »
Ah. I’ll try that tomorrow. Thank you.
Ten Over
Post by Ten Over »
Yeah, it's an export 135W. sluckey's got you covered on the reverb hum.
plookit
Post by plookit »
When I pull out these two plugs (one from the foot switch and one from reverb tank) the hum goes. It also goes when all are plugged in and the switch is turned off
