Silverface Fender Twin schematic
Could someone help me identify the year and schematic number of this Silverface Twin. The owner wants a mod to be reversed.
Re: Silverface Fender Twin schematic
Serial number indicates 1980 which would make it a 135W model. Picture of the rear and/or picture of the guts would verify.
If this is the export model...
This is fantastic. Thanks so much. I’ll get a picture of the back. I don’t have it in my bench yet, the guy wants me to put the hum pot back in. He says it was modded out of it some time ago.
So, the task is to put back a hum pot that was removed. The amp sounds great except when the reverb is engaged and then it has a lot of hum. Any thoughts on what that might be. It’s been sitting unused for a good while.
Hum pot most likely will not fix that. Does the reverb hum if the footswitch is disconnected?
No, hum goes when you disengage reverb
Ah. I’ll try that tomorrow. Thank you.
Yeah, it's an export 135W. sluckey's got you covered on the reverb hum.
When I pull out these two plugs (one from the foot switch and one from reverb tank) the hum goes. It also goes when all are plugged in and the switch is turned off
