Building a 5F6A Tweed Bassman clone based on Rob Robinette's site. Maybe a head only or a 1 x 12 or 2 x 10 combo. I'll be using it only at home but I tend to pass my builds on to my nephews who gig in bars and clubs.
Looking to add the following mods:
Multi-tap OT with at least 4 and 8 ohms. I guess 2 would be nice to go full Bassman ...
Type 2 Lar Mar master volume, full/half power switch. For home use and hearing preservation
JTM45-ish Lead mod in normal channel, NFB switch for 5F6A/JTM. BTW I know that this won't get me all the way to JTM
Adjustable bias, Anti-pop R, rectifier backup diodes
Here is the layout with mods added, it would be great to get other eyes on it to see if I have done it properly.
Right now thinking about Bassman Weber PT and Heyboer OT, any other suggestions?
Also any input on the utility of the mods I have selected as well as ones I may have missed.
BTW, I decided not to build a Dumble for now because I only play Strat and Tele and the Dumbly tone I like is mainly humbuckers. So the tweed Bassman seems to be the ticket to that warm classic overdrive tone for single coils.
Thanks!
5F6A Bassman clone, layout review please!
Re: 5F6A Bassman clone, layout review please!
Are you sure that the negative feedback resistor values have been scaled correctly?
A Marshall type chassis may make a much easier, more enjoyable build, and hence more likelihood of a successful outcome, than a tweed bassman chassis.
I'm using the NFB values from RobRob's site, I assume he did it right!
"If your 5F6A feedback is tapped off an 8 ohm speaker output like mine then your 5F6A feedback resistor should be 56k to give the same amount of feedback as the original 5F6A's 2 ohm output with a 27k feedback resistor. You should use a JTM45 equivalent resistor of 20k"
Agree on not using a tweed style chassis, was thinking about a Mojotone blond Bassman chassis 20 1/4" x 8 1/8" x 2". It looks like it will fit the 7 pots easier than their British 45 (JTM) chassis. Though the JTM is aluminum, which I would prefer.
