Hello,
i was hoping someone would comment on the electrical aspects of whether the reverb tank is connected or Not connected, if there is any loading or "un-loading" that can be expected to make a sonic difference.
Reason I ask is that I'm very close to finishing a single channel Pro Reverb type amp (no tremelo) and want know if I could start gigging with it just using my digital reverb pedal while shopping for tanks.
I've owned a couple of Fender AB763 amps but, its really been a while and I always just left the tanks plugged in.
thank you for your time!
Best,
Phil D.
Reverb tank connected vs not connected
Re: Reverb tank connected vs not connected
I'd say pull the driver tube so you don't get high flyback voltages on the reverb transformer (it's a SE amp OT), and switch he reverb off with the pedal switch to ground the recovery stage grid.
yes without tube no problem, and reverb pot put to the 0
Thanks very much guys,
That is very good to know!
Best,
Phil D.
Best,
Phil D.
