Trey’s Deluxe Reverb mods
Fender Amp Discussion
dr. who
Post by dr. who »
Pics of the mods done
All info from @trey99rig
Re: Trey’s Deluxe Reverb mods
Ok, so?
dr. who
Post by dr. who »
This is the fender amp discussion. It’s a rather famous deluxe reverb amp and mods. Some members here may find it interesting or useful.
JD0x0
Post by JD0x0 »
The 400VDC coupling caps in the PI are a bad idea. Mesas fail all the time because of this. 630VDC will be better.
It's because the -bias voltage is cumulative with the positive plate voltage. The cap 'sees' both these voltages added together. So if we had a -50VDC bias voltage and a 250VDC plate voltage on the PI, those caps would be 'seeing' 300VDC. Then factor in, when the amp is unloaded, those voltages can be higher.
I also think trimming up the values there could be a good idea. Gets rid of flub and blocking distortion.
rooster
Post by rooster »
This is somewhat interesting. So where did this come from? Is this Trey's actual amp that is pictured?
rccolgan
Post by rccolgan »
I think this is very cool!! Thanks for posting! Trey has a big following for those who follow his stuff so I appreciate it.
-Ryan
Ryan
https://www.thetonegeek.com/
Bombacaototal
Post by Bombacaototal »
Many thanks for the post, this is really helpful and cool!
