duane allman's marshall
I'd love to build a a non master bass amp like his.
Re: duane allman's marshall
The super bass 100 cheap way would be Ceriatone kit.
The www.tubeampdoctor.com has the 150w Bass amp kit.
Too expensive. Its the easy way out tho. Duane played a 50 watt super bass with c Vegas and something else. But his cab was a half open. Anyways I read that his amp had a few modifications to it. What they were nobody knows....or do they!?
What is the story on the 150 watt Super Bass kit?
I don't like KT-88's and Marshall's as the valve runs very cold and there is extra load placed on the amp. I don't think the tonal change is worth the hassle.
I think if you want to use KT-88's then use a transformer set that can run them properly.
That I have no idea about but that makes sense.
Here is the schematic and layout from their website.
The transformers seem to be dedicated transformers rather than using SLP-100 transformers. The power transformers on the older amps run hot, so it is good to see they've taken a smart option.
Is this an actual Marshall model as the circuit isn't familiar?
Richie The link didn't work for me.
try a 1986/jtm50 for duane
www.myspace.com/20bonesband
www.myspace.com/prostitutes
4x12" w/H75s
4x12" w/H75s
Didn't PRS have access to and "clone" Duane's Superbass Plexi? It's also switchable to Jimi specs, supposedly.
http://youtu.be/dgJwqUB4BjE
http://prsguitars.com/forum/showthread. ... #post92710
http://youtu.be/-c8iOSXgmSk
http://www.ebay.com/itm/2014-PRS-HXDA-3 ... 4add33e19c
http://www.ebay.com/itm/PRS-HXDA-Amp-He ... 3a82c4e980
just look up the info on..
Paul Reed Smith introduces the HXDA Amplifier.
...and the 3 HXDA switches do we know what they do?
Bypass cap switches? Cathode resistors maybe? Split plate load?
Thanks...
Thanks...
In theory, theory is the same as practice. In practice it's different.
The 3 switches control brightness and gain of the two HX/DA.
seem to control NFB and cathode bypass caps?M Fowler wrote:The 3 switches control brightness and gain of the two HX/DA.
4x12" w/H75s
4x12" w/H75s
