Thanks, I haven't worked on this amp since I posted but I did sell my Marshall 2061x 20w bass head so down one amp
I need to get back to the Duece's Wild and wire up the channel switching and insert jack for foot switching.
Two channel AFD 39 started
Re: Two channel AFD 39 started
Finished this two channel amp and loaded a WGS Reaper HP into the combo cab next it will get tested.
I know the Fender clean channel works very well but the HRP side is too bright and I will be adding 220pf ceramic caps from grid to cathode to dump some highs. Maybe remove one treble peaker cap.
Nce looking build! I love the way you labeled the pots for easy ID. Thats a brilliant idea!
Thank you, I had to label them I was confusing myself
