Master volume mod
Master volume mod
Here is a mod I've done to a few amps. Is your amp so loud that you never turn it up past half way on the master volume? This mod will give you more control over your master volume from 0 to 6. Do the mod I posted and now when your amp is all the way up it's it's actually turned up to 6 ( half way). This mod is nothing new but I thought I'd post it here for the people who don't know about it. This mod comes factory on the new KK JCM800 2203.
Keith
Keith
N
You should try out placing a 220K 1/2 watt resistor from one output tube plate back to the plate of the PI tube on each side of the OT, so in other words you only need one resistor for each side of the OT.
This will pretty close to cut 1/2 the wattage off of the amp.
You can raise the value you 330K for less volume cut if you like or install a DPDT switch to parallel or unparallel between two different cuts!
This still let's your preamp output over drive the output stage.
Re: Master volume mod
Stevem,
So
Your tying the plates of the phase inverter and output tube together with a 220k resistor ?
So
K
Yes, go look at a Fender Bassman AB165 schematic.
Re: N
Won't that (introduction of local negative feedback) reduce system gain rather than output power? eg a 40 watt amp will still be a 40 watt amp.Stevem wrote:You should try out placing a 220K 1/2 watt resistor from one output tube plate back to the plate of the PI tube on each side of the OT, so in other words you only need one resistor for each side of the OT.
This will pretty close to cut 1/2 the wattage off of the amp...
The mod will also reduce the range of the presence control, by reducing the max boost available when it's is set wide open.
T
Well when Fender changed the Bassman over to that circuit it cut its 45 watt RMS predsessor down to some 25 watts and when you pushed the amp into clipping you got near perfect square waving out of it, not that such may be what someone wants , but it sounds very sweet!
Like I posted you can go with double that 220K value that Fender used an just introduce a tad of local feedback, or whatever amount.
Such resistors may act to damp down back emf spikes so that may be a reason for a beneficial tonal effect.
I'll have to have a play with the idea!
I think that the same value of feedback resistor may have a different effect with a 12AX7 LTP than a 12AT7, due to the differing plate impedances.
- Malcolm Irving
Re: N
Maybe it works by reducing the gain of the 'PI and power stage' combination to the point where driving the PI to clipping no longer produces enough swing on the power tube grids to get them to full output?pdf64 wrote: ...
Won't that (introduction of local negative feedback) reduce system gain rather than output power? eg a 40 watt amp will still be a 40 watt amp. ...
- ElectronAvalanche
Hi SteveM,
sounds like a nice mod to a JTM45. What type of DPDT switch rating would one need. If the switch is after the resistor voltages should be lower than B+ of the output tubes and maybe acceptable for a 250VAC switch?
Electron
Electron
Re: N
Thanks for this. I just installed these resistors using the old polarity switch in my bassman. It works nicely and definitely adds some nice growl when in use....... and knocks off a fair amount of DBs.Stevem wrote:You should try out placing a 220K 1/2 watt resistor from one output tube plate back to the plate of the PI tube on each side of the OT, so in other words you only need one resistor for each side of the OT.
Question: Can this switch be used with the amp running?
Re: N
Answer is NO!studiodunn wrote:Thanks for this. I just installed these resistors using the old polarity switch in my bassman. It works nicely and definitely adds some nice growl when in use....... and knocks off a fair amount of DBs.Stevem wrote:You should try out placing a 220K 1/2 watt resistor from one output tube plate back to the plate of the PI tube on each side of the OT, so in other words you only need one resistor for each side of the OT.
It seems like you've tried it and something unwanted happens; what was that?
Typically I would answer yes followed by a story of regret and sorrow, but not this time.pdf64 wrote:It seems like you've tried it and something unwanted happens; what was that?
I just PM'd Mr Fowler for some straight up advise and he kindly told me not to switch while running.
That said, it works well, but the amp has a hum present when the resistors are in use. I may need to reconsider there relative position to the OT's and rewire things.
Re: N
Something like the attached schematic (this is SE, just double it for PP)?
Just wondering how many people have tried it and like it?
Is it limited to a long tailed pair?
