JTM build
Marshall Amp Discussion
dcribbs1412
JTM build
Post by dcribbs1412 »
Gonna see if I can put together another decent JTM 45ish amp
D
JoeCon
Re: JTM build
Post by JoeCon »
Nice, very nice. Just add some solder!!
In theory, theory is the same as practice. In practice it's different.
dorrisant
Re: JTM build
Post by dorrisant »
Get the board from AES/CED?
dcribbs1412
Re: JTM build
JoeCon wrote:Nice, very nice. Just add some solder!!
will do asap :)
dorrisant wrote:Get the board from AES/CED?
using mojotone board,chassis and headcab
D
Re: JTM build
I've build a few and they sound good but what do you like about the JTM45?
I like something with a little more tube distortion. :D
dcribbs1412
Re: JTM build
M Fowler wrote:I've build a few and they sound good but what do you like about the JTM45?
Hi Mark
for me personally it goes back to my first encounters with a Marshall.
A friend of my brother had an early original and I was new to guitar
and was blown away with the tones. I remember it was pretty much cranked with a 4x12 and it was like hearing all my guitar heroes tones.
In the right hands...
https://www.youtube.com/watch?v=VLjrJdT0Nec
https://www.youtube.com/watch?v=s5bk_Rb6qAw
https://www.youtube.com/watch?v=kFWQr8O6BJE
Re: JTM build
I see.
Might have to crank mine up tonight with Les Paul. :D
ToneMerc
Re: JTM build
Post by ToneMerc »
dcribbs1412 wrote:Gonna see if I can put together another decent JTM 45ish amp
D
That's looking great D!
TM
Littlewyan
Re: JTM build
Post by Littlewyan »
This will be awesome. I built myself a JTM50 few years back and I love it.
If you want more drive Fowler then don't forget to crank the presence. It adds quite a bit :).
dcribbs1412
Re: JTM build
Finally got time to add some solder and fire her up.
Decided to go with the HT tapped bias (PT has a 50V bias tap)
460V on plates biased at 37ma. (a little on the high side)
Initial tones are promising, will do some burn in, roll tubes and go from there.
Will post pics of cab we she is done.
D
Colossal
Re: JTM build
Post by Colossal »
Very, very nice! 8)
Which KT66s are you using?
dcribbs1412
Re: JTM build
Thanks Dave
Valve Art 66's.
So far they settled about 2ma apart.
Seem to be decent tubes. Longevity...not sure,
hoping my bias circuit can accommodate 6l6's and el34's too.
D
Bob S
Re: JTM build
Post by Bob S »
Now that's a good looking JTM.
There's a feelgood factor when you play through an amp that's beautiful under the hood. That will have it.
Nice.
Why Aye Man
gktamps
Re: JTM build
Post by gktamps »
Looks nice!
On the Valve Arts KT66; I am using them in my Merren - transformer high voltage JTM45. They sound great and have been quite stable now over about 50 hours. I did have to adjust my bias circuit though. I just put a pair in my big bottle Rocket, though yet to fire it up.
Greg
dcribbs1412
Re: JTM build
gktamps wrote:Looks nice!
Greg
Thanks Bob
agreed on the feelgood factor
Just like taking a little time with the builds lately.
Usually translates into decent looking inside and out.
Which doesn't always but more times than not turns out a good sounding
amp. At least a good point to start tweaks.
Hi Greg
what voltage you running the KT's at?
D
