Marshall JMP Master Volume 20W Build
Marshall Amp Discussion
Littlewyan
Re: Marshall JMP Master Volume 20W Build
Post by Littlewyan »
Sounds good to me. I'm tempted to add a few mods like that but have held off for now.
Yeah I had to use a non-CT PT which add some complications. Not the end of the world though.
I actually thought this amp sounded quite harsh with the master volume low until I changed out V2 in it. It was a JJ ECC803S and I replaced it with a JJ ECC83 MG. Much better!
One day gldtp99 I will build a monster amp like that! Until then Ill stick with my 20W and 50W amps :P. Try and find a 4x15 Cab for that Superlead and move into Lemmy territory!
gldtp99
Post by gldtp99 »
The guy that bought my 6V6 x 2, 2204 type head brought his band over to try out amps---- they played a Motorhead song while they were there----- the bass player was going through my Metro 100 watt MV head (KT88 x 4) when it was still in mostly stock 2203 configuration.
One way to go about building a bigger amp is to pick up an old Sound City 120--- gut the orig circuit and use the big orig iron and EL34 x 6 with the preamp of your choice---- you get a very solid steel chassis with plenty of pre-punched holes for the preamp tubes so you can configure almost any preamp you can come up with.
The output section on those amps is powerful and great sounding---- I think the 120 watt rating is very conservative with these monsters.
More power than most people would ever really need----- this is the output of one of the Hiwatt preamp SC 120 conversions I did early on:
Sometimes these old amps can be picked up cheaply.................. gldtp99
PS: The owner of the SC 120/War Elephant (high gain single channel) amp I did says it "Comes Through" in live rehearsal/gigs better than other big high gain amps he has----- "Power" has a way of penetrating, and can be heard/felt, without being blastingly loud in some situations------ but Power also penetrates through walls, ceilings, floors, etc and can get the police called on you sometimes.
Littlewyan
Ah yeah they come up on Ebay every now and then.
Power definitely gets through the walls in my house! I can't even play a 1W amp in this house without everyone hearing it!
