Switching from cascaded to parallel bright / dark channel?
Marshall Amp Discussion
titser_marco
Post by titser_marco »
Hi! Just built a plexi super lead inspired circuit and I am loving it. Been doing more reading and I discovered that later Marshalls were essentially the bright circuit feeding the dark circuit in the preamp.
I'd like to be able to switch between the two modes and I was wondering if you guys had a schematic showing this switching scheme. Thank you!
Sent from my SM-N910C using Tapatalk
Roe
Re: Switching from cascaded to parallel bright / dark channel?
Post by Roe »
there is some layouts to be found on the metro board. I prefer switching from 1959 to 2203
www.myspace.com/20bonesband
www.myspace.com/prostitutes
4x12" w/H75s
titser_marco
Roe wrote: Tue Jun 27, 2017 7:27 am there is some layouts to be found on the metro board. I prefer switching from 1959 to 2203
Thank you. Do you have a link to the said board?
Roe
Post by Roe »
4x12" w/H75s
Roe
Post by Roe »
4x12" w/H75s
titser_marco
Thanks! All the links are dead but at least you've directed me to another great forum!
Tried my hand over lunch and this appears to work. Could I ask for a once over from you guys and let me know if this will work?
Roe
Post by Roe »
4x12" w/H75s
