Everything weird happens between 4 and 6AM
10h-.68u over 2k7. The neighbors have to be truly impressed. The peak is near 100Hz. I upped the plate to 220k no bypass required.
Tried it on stage 3. Dropped a tad more gain that I bargained for although the action plays out more plainly as a late stage bypass. It's by no means lost in translation as stage 1. It makes a lot of sense. (and a tremendous roar.. rawr..)
I need some screws!
I need some screws!
Re: Everything weird happens between 4 and 6AM
You're using a choke for that? I had something smaller in mind like inside the chassis .
- cbass
Do these do stuff?
Yes. Where did those come from? That sure fits better and doesn't freak out if it's oriented poorly. LOL
10H and .68u resonates at 107Hz. Larger cap lower peak.
Good calculators based on the things you know values of.
https://rimstar.org/science_electronics ... ircuit.htm
Organ donor. You can have them if you want. theres about 12 or so
I just need one 10h for a cathode that doesn't have to be mounted to the side of a headbox lol
I feel like I missed part of the conversation. Is there a schematic?
Nope. Ain't no schematic, buddy.
What are we talking about here? Adding an inductor across an Rk to try to get a specific frequency boost?
- dorrisant
I wonder how this worked out for him.
Miles! You have some splainin' to do...
Btw, what's up Ray? Haven't seen you in years.
