Lead 100 Watt started
Re: Lead 100 Watt started
Thanks Aaron, what do you use to tack wires to the chassis. Quick drying silicone? Any particular brand. I have had some silicones that seem to never dry. Maybe hot glue gun?
I use 3M stick on squares like you have, or UV-cure adhesive, and in rare cases, hi-temp hot glue.
Aaron, I have the preamp grounds on a bolt that the choke is using, should I move that or will it fly?
Ange
Ange
You're using a bolt that secures the choke to the chassis as a ground point? OK, I guess.
Yes, its in the right spot. Just wondering if there might be any current through that connection that would induce hum.
No current in the metal housing of the choke--it will be at ground potential.
Very kind, sorry to keep pulling you away from work.
A
A
Don't be silly. I live here.
Gonna populate board soon.... I know very slow boat here.
So my understanding is that with a PPIMV dimed its essentially same as circuit with 220k's no PPIMV (In a Marshall SL 100W) True?
yes
www.myspace.com/20bonesband
www.myspace.com/prostitutes
4x12" w/H75s
4x12" w/H75s
When I run the PPIMV wires, my plan is to shield the pair of wires that run to the 220k spot and 5.6k's terminating the shield at one end. I know the shield can be used to run the bias wire as well. If I go by the Metro layout and use a separate wire for the bias run, should that be a shielded wire as well?
No, the bias does not need to be shielded.angelodp wrote: ↑Thu Feb 04, 2021 3:22 am When I run the PPIMV wires, my plan is to shield the pair of wires that run to the 220k spot and 5.6k's terminating the shield at one end. I know the shield can be used to run the bias wire as well. If I go by the Metro layout and use a separate wire for the bias run, should that be a shielded wire as well?
Perfect thanks Aaron.
Aaron, above board jumpers, I am thinking teflon 20g or 22g.... yes?
Which jumpers? What function?
