Marshall Superlead Normal Channel
Marshall Amp Discussion
66Fuzz
Re: Marshall Superlead Normal Channel
Post by 66Fuzz »
I like to mod the normal channel with two simple component changes.
1. Switch the 820 cathode resistor to 1.5k
2. Switch the .022 coupling cap to .01
That's it...
matt1969
Post by matt1969 »
Been a while but I'm back!
I had to put this aside for a while.... So this weekend I tried a 470pF bright cap on the normal channel's volume and that help a lot and sounds pretty good! Will a 47pf like what was suggested even sound better?
Thanks for all of the suggestions.
Is the 470 too much from a frequency analysis standpoint?
The circuit doesn't care. Let your ears say what value is correct for you.
WhopperPlate
Post by WhopperPlate »
matt1969 wrote: Tue Mar 28, 2023 11:06 am Been a while but I'm back!
If it works it works . 500p is a common bright cap value . Obviously not stock to normal channel .
I tend to to emphasis the following : I betcha the increased bass is a result of aging parts , and careful part swapping on the normal channel , or possibly capacitors within the power supply . Increased ESR in caps can really smear the sound. Also pay attention to any carbon comp resistor value drift if they are in there .
You can band aid this with bright caps and value changes , but it won’t treat the infection .
Charlie
matt1969
Post by matt1969 »
Turned out to be a faulty solder joint under the PCB! Thanks for all of the replies!
bepone
Post by bepone »
for me is too much, but this depends of the guitar.. usually for normal not bassy guitar is cca 150-220pF enough
