Tremolo 50w service
Marshall Amp Discussion
Tremolo 50w service
Servicing a Marshall Tremolo 50w pretty much original a few things have been worked on. Power cord is completely crumbling in my hands. One wire on standby switch is undone. Pilot light broke.
Fun amp for me to bring back to life.
sluckey
Re: Tremolo 50w service
Post by sluckey »
Looks like a Billy Gibbons hat on those power tubes. :wink:
I have 4 NOS caps to use in my SL100 Marshall clone build.
Reeltarded
Post by Reeltarded »
oh it wants me to strip it and make it scream!! look at it flirting at me with that 7 inches from sensible 4th noval.
i'm a killer. that one looks pretty good!
hmmmmm shared, drilled board.. 10333... .1u.. pancake mix bypass.. 1968.
It is even a BB. Which cabinet did it come in? Does it have a valance or just cloth front?
Reeltarded
Calling Roe. Come in, Roe. beee bedee dee deee deee de dee deee dee
Small box head with valance.
bepone
Post by bepone »
Full iskra resistors inside :wink: ! Ex Yugoslavia, we were producing everything. Now it is only part of history. Looks like PI resistor 470R has been replaced for CC
Reeltarded
M Fowler wrote: Sat Dec 10, 2022 6:42 pm Small box head with valance.
Has combo lip
Roe
Post by Roe »
Reeltarded wrote: Fri Dec 09, 2022 4:05 pm oh it wants me to strip it and make it scream!! look at it flirting at me with that 7 inches from sensible 4th noval.
the 50w tremolos used the bass circuit, while theh 100w tremolos (supertremolos) used the lead circuit. So .1uf does not indicate 1968
www.myspace.com/20bonesband
www.myspace.com/prostitutes
4x12" w/H75s
Reeltarded
Ahh I mean the pres and I meant Mustard .1. Earlier amp is different and later amps end up with mixed brand caps. I used the serial range to predict production above my JTM50. Look at the bias trimmer. I think it's mid 68 and lost it's head hutch.
It has a combo lip. Somewhere, there is a sad lonely and expensive cabinet remnant under a bunch of rotting food waste and ink stained Barbie heads.
pdf64
Post by pdf64 »
M Fowler wrote: Fri Dec 09, 2022 2:05 pm Servicing a Marshall Tremolo 50w …
Would you mind measuring the resistance of the HT winding? ie from the PT winding lug with anode of one rectifier diode to the anode of the diode on the other lug.
TIA.
Sure I can measure.
It has a beat up 4x12 cab.
pdf64 wrote: Thu Dec 15, 2022 3:06 pm
TIA.
It reads 77.4 ohms
From diode to ct 39.6 and 37.6 other side.
Plate voltage 421vdc
Head cab. Myles is that your paint work?
Reeltarded
wow I LOVE THAT
It appears to have combo mounting holes for the front lip. I have only ever seen two heads done that way but maybe 10 heads with the lip.
