http://www.freeinfosociety.com/media.php?id=3281
I have a Kendrick Roughneck which I've modified.
[IMG
[IMG
The mods consist of getting rid of the 470K input resistors (one with treble boost/shunt on it) I went back to stock as I didn't like the tones and having half the input signal made the amp noisy.
I wanted a bit more volume so I stuck with the 6L6 and the 5AR4, this is an issue as the screen current causes excessive compression in the pre-amp, basically I used a 47uF filter cap on the node feeding the output transformer and 47uF on the node feeding the screen grid, I also used a 1K screen limiting resistor for good measure. I did try lowering the 10K screen power supply resistor, but the voltage was more than the various tubes I had could bear.
I also like Ted Weber's Silver Ten in this amp, it certainly isn't Celestion like, but it does have a lot of bottom end which the amp needed. It sounds more balanced.
I have had a lot of problems with Champ volume pots which incorporate the power switch, the wiper on the pot tends to go. I have just put in a Ted Weber 1M volume pot/switch in the amp after a couple of Alpha pots that went bad. So far it is going okay and I like the 30% taper it does get loud quick but I don't use a bright cap as I did with the Alpha pots.
I also used an output transformer with a 5K primary which gave the amp an 8 watt output. I was rather keen on the amp at this stage till I realised the power transformer was running too hot. The amp was a bit louder than a stock Champ, but it sounded quite a bit fatter and warmer (could be the speaker too). It did occur to me to get a bigger power transformer, but even after careful measuring the transformer still too big for the cab and chassis.
Oh yeah I also used a grid stopper on the output tube which helped the amp from becoming too bright as it distorted.
Due to the power transformer it is back to the drawing board on this one. I'll see what I can do with the stock 5Y3 and a 6V6. I'm also considering adding an extra stage of filtration to remove excessive mains hum.
Again any thoughts?
