I was wondering if there are any builders here or if anyone knows one that makes a Trainwreck Express inspired amp that uses preamp tubes for output tubes (1-3 watts) that is push-pull and not single-ended. I have seen some single ended amps like the Mini Wreck but am looking for something lower wattage and push-pull.
I have been looking at an amp by a builder here on the forum that is similar to what I am looking for but am having a hard time with the price point being too high. What would a fair price be for a 1-3 watt Express inspired amp?
Any input is greatly appreciated!
low watt trainwreck
Low Wattage Amp
Since price is an issue may I suggest the Super Single Ended Guitar Amp at Angela Instruments.
Follow this link: http://www.angela.com/
And click on the How To Section.
It isn't push pull as you requested. But it's a low wattage single ended design that runs a pair of output tubes in parallel to increase the wattage a little. I was pricing it out and you could probably build it for under $200. Not including speaker. Especially if you already have some of the passive components.
I was able to build my Trainwreck for about $600 including the addition of the Power Scaling and Bias Mod. It was worth every single penny spent.
Steve
Steve
Re: low watt trainwreck
You could use a dual triode like a 12AT7 or an Octal equivalent for the power section. You could also use a small dual pentode.
Eardrums!!! We don't need no stinkin' eardrums!
What about the mini Wreck?
The mini -wreck looks great (Steve sent me the link and I have read his posts). The big difference between that and what I am looking for is single-ended vs. push pull and that 5 watt range vs. 1/2 to 1 watt range. I have owned numerous 5 watt amps and they are just too loud when cranked for home playing.
Still looking...
Still looking...
The Moonlight amp uses a 6SN7 for a power tube and about 1W in push-pull. Shouldn't be too hard to graft any of a number of preamps onto this design.
I am thinking of drawing up a few designs and this power section is one that I have been wanting to try for quite some time now.
http://www.amptone.com/delftmoonlightamp.htm
Can someone point out the link to the Mini-Wreck?
