Manzamp!
Manzamp!
My next project:
[IMG:527:79]http://img.photobucket.com/albums/v670/ ... mpLogo.jpg[/img]
[IMG:707:463]http://img.photobucket.com/albums/v670/ ... gress1.jpg[/img]
Schematics (indicated voltages are descriptive, not prescriptive):
Re: Manzamp!
Very cool, I have to give it to you as you take your clones to the 9's. It's good to see other Dumble topologies lately, something other than the ODS.
I finally found me a relatively clean, cheap and working donar Fender (Super Reverb) chassis for my next Dumble build, one of the UP versions.
TM
TM
Re: Manzamp!
I always liked the idea of this amp but lost interest after talking to one former owner. Still I always loved the construction and still can't grok how this sort of amp, set-up and running properly, would not kick ass.
Look forward to seeing and hopefully hearing this one m8.
"...& I'm all out of bubblegum"
Re: Manzamp!
Re: Manzamp!
I don't want to be like some who keep secrets here, but I want to build the amp first (and be the first one here to do so) then I'll show and tell all. I hope this turns out to be a good amp for people interested in an easy-to-build Dumble circuit. It does not have all the complexity of 100w and the switching and the pre-amp switches of most other Dumble circuits. That will make it easier to build. I hope the architecture I'm working on for that main board will live on in many interesting tonal interpretations once I post the final version and schematic.ChrisM wrote:What are your resources for this project?
I'm impressed!
Re: Manzamp!
Very cool, I'm anxious to see the final result.
Hopefully this build doesn't take quite as long as your HRM did.
- JazzGuitarGimp
Re: Manzamp!
IC, what program is that you're using?
Lou Rossi Designs
and Schematic Capture
Re: Manzamp!
Aldus Freehand c1992JazzGuitarGimp wrote:IC, what program is that you're using?
I keep an old iMac up and running because, frequently the older software is easier to use and runs faster. Plus I have a lot of old software. I like Macintosh, but I'm disappointed that my new 27" iMac can run Windoze but not 68k Macintosh software!
Re: Manzamp!
I ordered the raw materials for the chassis and PC boards yesterday. Tube sockets and filter capacitors are on the way also.
Re: Manzamp!
I'm very interested in both the Manzamp and the UP TM is building nice projects guys.ToneMerc wrote:Very cool, I have to give it to you as you take your clones to the 9's. It's good to see other Dumble topologies lately, something other than the ODS.
TM
Re: Manzamp!
TM
Did I miss something?? The Ultra Phonix has been de-coded?? I check in most days, maybe it's time to stop sniffing glue........
Eric
Re: Manzamp!
Subscribed....dreric wrote:ToneMerc wrote:Very cool, I have to give it to you as you take your clones to the 9's. It's good to see other Dumble topologies lately, something other than the ODS.
TM
Eric
Re: Manzamp!
Chassis arrived today.
It is pretty thick because it has no end plates. I'll probably take it to a local machine shop to cut the holes, unless it is stupid-expensive. In which case I'll just spend the money on some metal hole cutting bits.
[IMG:640:480]http://img.photobucket.com/albums/v670/ ... 2/file.jpg[/img]
Re: Manzamp!
Dimensions of what I am making
Chassis = 16" x 3" x 5"
Thickness 0.19" aluminum
Cutout for transformer:
[IMG:387:325]http://img.photobucket.com/albums/v670/ ... CUTOUT.jpg[/img]
