Transformer Current Rating
- Littlewyan
If I used a Full Wave Rectifier on a Centre Tapped Transformer, would the current rating of the transformer double? As I'm only effectively using one winding at a time. As looking at the Marshall PTs Available from various companies they are only rated at 150Ma, which for EL34s is nowhere near enough.
Re: Transformer Current Rating
No.
- Littlewyan
So why on earth are the Marshall PTs rated at 150Ma? I used a 288Ma PT for my Express.
- Littlewyan
Jesus Fowler I hope you were referring to the Current Calculator on that thread. VacuumVoodoo's post just drained me, too much info at once! Am I right in saying that he is basically saying to get max clean output from the valves a properly designed PSU is required? So Marshall's use of an underrated PT may have been intentional?
I thought it was a good link.
Basically stating 150mA classic tone MCI transformer is good for 50w.
- VacuumVoodoo
How do you eat a whole elephant?Littlewyan wrote:Jesus Fowler I hope you were referring to the Current Calculator on that thread. VacuumVoodoo's post just drained me, too much info at once! Am I right in saying that he is basically saying to get max clean output from the valves a properly designed PSU is required? So Marshall's use of an underrated PT may have been intentional?
Slice by slice....
Aleksander Niemand
Life's a party but you get invited only once...
affiliation:TUBEWONDER AMPS
Zagray!-review
Zagray!-review
- VacuumVoodoo
multiple post, forum reported "debug mode"
Aleksander Niemand
Zagray!-review
Zagray!-review
- VacuumVoodoo
Aleksander Niemand
Zagray!-review
Zagray!-review
I know your standard of living is high, but I didn't realize you were eating elephants up there!
- Littlewyan
Right, so basically 150mA is fine, it just means I will get sag, which is probably part of the early Marshall sound. However if I want my Amp to have maximum headroom and produce maximum clean Output then I should use a better Transformer?
I also often hear that only one valve is conducting at a time, is this taken into consideration?
In class B, yes, they conduct alternately. In class AB the conduction overlaps during each cycle. In class A they both conduct through the whole cycle... and the box gets even hotter!
Cheers,
Roger
Cheers,
Roger
Keep the old 'uns playing!
