So, after extensive play, I determined that I needed a PPIMV, and installed a Lar/Mar. I put the MV pot in place of the Normal pot, and bent the Normal pot over on it's buss wire, and soldered the ground tab to the ground tab on the Bright pot.
I'd like to install a dual 1 meg pot to replace the individual pots for Bright and Normal, is there anything special I need to watch out for, or is this a straight shot ?
New 1987 Build Marshalling Forward.
Re: New 1987 Build Marshalling Forward.
edit: Double post.
