Rocket almost done
Richie
Rocket almost done
Post by Richie »
I haven't posted much in a while. So here are a few pics of a Rocket amp. Still need to Clean it up some, finish a few things, and play it some tomorrow. Plus some tube rolling.:)
Re: Rocket almost done
Nice job Richie very sweet build.
Post by Mark »
Beautiful build Richie!
Can you tell us about the tube rolling.
KellyBass
Post by KellyBass »
Great build, Richie!
I'm interested in hearing about your rolling adventures as well.
This message has been printed using 100% recycled electrons.
Richie
Post by Richie »
Tube rolling, just going through some tubes I had. I have some Russian tube for the EL84s. And some RCA 7025 in V1, and RCA short plate in the second position,and V3. The V3 is perfectly matched exact on each triode.
I did couple things, very small changes. One is I used 40uf filter over the 80uf. mostly because if someone uses the more current made GZ34. Plus I think 40uf is fine. Although a nice GZ34 would be great to have.
Its also very quiet, till you hit a chord..:)
This amp sounds fantastic!!!
BLT
Post by BLT »
So Richie, you're saying that you used one 40uf instead of the usual two 40ufs in parallel?
BLT
Richie
Post by Richie »
No I used 2 20s
gktamps
Post by gktamps »
Another beautiful build, Richie.
Still diggin' the Liverpool you built.
Cheers,
Greg
Colossal
Post by Colossal »
Very nice man, looks real sharp.
Richie
Post by Richie »
Thanks for the comments :)
RJ Guitars
Post by RJ Guitars »
Richie, it's really nice to see some of your work again. The number of builds these days seems to be down, maybe cold weather will get things cranked up. Is that an original Stancor output tranny or? looks like the real deal. Thanks for posting the photos.
http://www.rjguitars.net
Richie
Post by Richie »
No its a pacific OT.
