Thanks for the info guys
My .125" thick FR4 board is 3.125 inches tall
I have it sawed up on a CNC saw machine and then shipped to me
Years ago I use to saw up the sheets myself on a table saw
I now have it ripped up by my supplier and they do a way nicer job that I ever did
I don't rip it length wise here any more because it was such a huge PITA
I only cut it to length
If having boards 3.125 inches wide is not a problem, I can make the power supply board and the main boards?
Here is couple examples of the FR4 boards I make with eyelets
New source for ODS boards?
Re: New source for ODS boards?
https://hoffmanamps.com - Website
https://el34world.com - Website
https://el34world.com/Forum/index.php - Hoffman Forum
https://www.facebook.com/Hoffmanamps/ - Facebook page
https://www.youtube.com/channel/UC6QMFC-nnVtRyjCIIwNnBqQ - YouTube channel
Looking at the documented layouts for #102, #124 and #182, would it be accurate to say that the main/preamp board is pretty much the same board for all 3 amps?
But the B+ rail layout board is different for each of those?
So, one would use the same main/preamp board and just switch out the B+ rail board to do each of those?
With respect, 10thtx
- ValvElectric
To the best of my knowledge, though some of the preamp board values vary, the layout remains pretty much unchanged.
As for the power supply boards, the layout of #102 and #124 are relatively similar, whereas the precision power supply on #183 is a bit more complex and calls for a PCB.
Doug, it wasn't until recently that I noticed your relay boards and had contemplated giving them a try in my next build.
Does anyone else have any experience using them?
That makes it easier if I only have to make one type of board
I sell tons of the relay switch boards
The Power supply boards and single relay boards
I've used Doug's relay boards on 4 builds and they are superb and very easy to work with. Very quiet and they work great!
And there is a ton of info on EL34 world on how to hook them up complete with photos, schematics and layouts.
http://el34world.com/Forum/index.php?topic=14348.0
And even more in the Hoffman Library of Information
Thanks 10thtx
The library hook up info page for my relay boards is here
http://el34world.com/projects/relay_switch.htm
[img550]http://el34world.com/projects/images/Img_7549.jpg[/img]
Hey guys- I've received a few emails and PMs regarding the boards. I have a few remaining individual boards if Doug or others can supply the main and relays. I'm not able to update the website at this time as the computer I used to build it is in storage between recent moves.... Below is what is left & I just updated PayPal to not oversell anything. Please allow a few days to process and ship. Thanks.
(15) Precision Power Supply
(14) Standard Power Supply
(10) Bias/Rectifier
(6) Relay Power Supply
(30) FET
(11) Small (FET) Insulator
(10) Bias/Rectifier
(30) FET
http://agbamplifiers.com/
Dumble Clone Circuit Boards
The agbamplifiers.com site is dead. Where can I get a precision power supply board?
- dorrisant
Dave (Colossal) maybe?
