Two Rock Jet/Custom Reverb
Hi, is true that these are based on the Dumble 102? If so how close are they to that amp? Are they based on the ODS at all? Also, I have the Jet 35 and it seems kinda muffly especially on the G and D strings. I know about the Reverse Speaker Polarity. I used Gibsons and a G1265 Creamback. Only way I seem to get what I want is to pull out the Treble and Deep Switch...is this normal? Thanks!
Re: Two Rock Jet/Custom Reverb
no one?
How about a few pics or a traced out schematic? Makes determining the lineage a lot easier...
The Custom Reverb V3 is basically a 183 ODS with reverb/loop. With a contour control in lieu of presence.
Didnt the 183 have El34? CR has 6L6 or is that just a technicality?
the original custom was a copy of kimocks 70's ODS... they changed the layout and added their effects loop, and said it was a tonal clone they did by ear... then they later added reverb and that started the different versions of the custom... 102 was the TS1 amp as far as I remember.. they copied the layout on that one for the first time...
