Showman Amp
Fender Amp Discussion
Goldhedge
Showman Amp
Post by Goldhedge »
Just acquired this amp from a friend of mine.
It has the 2 JBL silver dust cap 15's cabinet under it.
Looked up the serial number and it's a 1960 vintage.
Originally, it was a blonde blackface, but sadly someone along the way dyed it black with something (leather dye?).
You can sorta see it on the cabinet edges...
I read it was typically used as the 'surfer sound'... plays really clean too.
Anyone know what it's worth? Suggestions on what to do with it?
Took a bunch of pics inside...
TIA
Colossal
Re: Showman Amp
Post by Colossal »
Goldhedge wrote:Just acquired this amp from a friend of mine.
The interior is pristine :shock: and it looks like it's seen very little use. To do with it? You're not thinking of modding it or something, are you? Only thing I would do is clean the dust off the front panel and tolex. Wow, that is a very nice score.
Goldhedge
Re: Showman Amp
Post by Goldhedge »
Thanks! I'd probably sell it.
I've been looking online and the speaker box (I think it's called a Bandmaster?) goes for about $400 and the head is around $800? Anyone have a better price?
Being that it's pristine and the first year model it could fetch more?
It is clean. I wasn't planning on modding it.
If it had reverb I might have considered keeping it.
Did I say it was loud? 4-6l6's with 4-12AX7's
Still has the 2 prong plug.
Colossal
Re: Showman Amp
Post by Colossal »
That is a nice amp, man. Hope you get a good price and a good home for it. Very nice! It is remarkable how clean the interior is.
ToneMerc
Re: Showman Amp
Post by ToneMerc »
Nice score; I would document the pot and electrolytic cap codes and of course the codes on the transformers, that would give a better clue of its actual age range. At first glance, it looks like a transitional 64'.
TM
Re: Showman Amp
Time capsule for sure. The date codes on the chassis, electrolytics, and bias pot seem to say late '63.
Goldhedge
Re: Showman Amp
Post by Goldhedge »
Hmmm, this is what I was using to date it, but it seems it's a crapshoot....
http://www.ggjaguar.com/fendamp5.htm
If you scroll down to Showman
Showman 6G14, 6G14-A (blonde)
00001 to 00350 – 1960
00200 to 00800 – 1961
00800 to 01500 – 1962
01500 to 01800 – 1963
from the link:
"Working at FMI – I was able to interview a fellow (who wishes to remain anonymous) who worked at Fender in 1972-73 in the amp department. Although his job was somewhat limited, his recollections provided some really fascinating insights to how the amps were built. For instance, he confirmed our assumption that the amp chassis were put into stock after being stamped with serial numbers and that the chassis were pulled from the stock bins randomly (just as with Fender guitar neck plates). He recalled, “We just went to a big bin every morning and loaded our wheeled rack with a batch of whatever chassis we were working on that day. The boss came around and said what we'd be building. The chassis weren't used chronologically. Probably the same as the pots and transformers that we just dug out of the boxes. I think in the corners of the boxes were older pots remaining from earlier dates... leftovers.”"
Re: Showman Amp
What are the numbers on the transformers?
ToneMerc
Re: Showman Amp
Post by ToneMerc »
Goldhedge wrote:Hmmm, this is what I was using to date it, but it seems it's a crapshoot....
from the link:
Other things to consider are hardware/ dressing type. That grill cloth, logo and handle type wasn't typically seen in 1960. Also, keep in mind there are also "transitional" models which use cosmetics across different eras, Fender did not believe in wasting parts and materials.
I have a rare AA165 Bassman that has mostly mid 64 iron, all 64 pots, all 64 lytics besides one dated 1/65, thus has to be early 65'.Suposely, they were only built between Jan-April 65'.
TM
Goldhedge
Re: Showman Amp
Post by Goldhedge »
Tranny pics... I think I have read the output correctly? Zoom in.
Re: Showman Amp
The transformers and choke are Schumacher (606), and the date codes are '63 (3), followed by the week of manufacture. The OT code doesn't make sense with 387, so it must be something else. With a 7 on the end it has to be 1 to 4, most likely a 3.
Goldhedge
Re: Showman Amp
Post by Goldhedge »
Thanks! That's still a 'pretty good year'!
“The greatest energy of movement will be obtained when synchronism is maintained between the pump impulses and the natural oscillations of the system.” Tesla
Bob S
Re: Showman Amp
Post by Bob S »
Neat wiring compared to the rats nest that we see in amps made a few years later.
Great Score!
Why Aye Man
MakerDP
Re: Showman Amp
Post by MakerDP »
Did it come with the paper tube chart stapled to the inside of the head? If so, post a pic of that.
Goldhedge
Re: Showman Amp
Post by Goldhedge »
Alas... it appears to be torn out.
Now why would someone tear it out so neatly??
Or do they tend to fall out after years?
