Input sensitivity switch?
psychepool
Post by psychepool »
I want to switch input grid stopper resistor in my diy amp.
Originally, it was 68K. I want to switch it 33K by add 68K parallel.
I measured it after installed a resistor and a switch. It was measured as 68K / 33K as desired.
However, when I turned on the amplifier and operated the switch, I could not feel any change.
I installed it like below.
Theoretically, I do not think there is anything different from the high / low inputs commonly used in vintage amplifiers and why does not it work?
Please let me know if you have any problems with switching in this way.
sonicmojo
Re: Input sensitivity switch?
Post by sonicmojo »
There is a difference from your wiring in the vintage amps. For example in a Twin Reverb AB763,it is essentially dividing the signal to ground with the 2 68K resistors when you plug into the #2 jack.
Bryan
psychepool
Oh, you're right!
Then, is the result like this?
Littlewyan
Post by Littlewyan »
Not quite. When you plug into the low sensitivity input on a Marshall 1987 or Marshall 1959 (I think most Fenders are the same) the wiring puts the 68K to ground after the grid leak resistor forming a voltage divider.
http://drtube.com/schematics/marshall/1959-01-60-02.pdf
Here is a nice clear schematic so you can see how the input wiring works.
psychepool
Is it right?
Can I operate it with DPDT switch? I want to make it with DPDT push-pull potentiometer.
psychepool
Dose it function?
Littlewyan
No that will put the 68K to ground before the grid stopper, it needs to come after it. Sorry I don't have time at the moment to draw anything up for you
psychepool
Maybe this is right. But there seems to be a loud pop noise.
Colossal
Post by Colossal »
How about this? In the High position there is 68k || 68k for 34k/1M. In the Low position there is 68k / 68k.
psychepool
Oh, you re genius! Thanks!
