Slowing down BF fender tremolo?
Fender Amp Discussion
Bombacaototal
Re: Slowing down BF fender tremolo?
Post by Bombacaototal »
Firestorm wrote:Ceramics are also compact in 1KV or 2KV ratings. This may help minimize leakage which can hurt the oscillator's performance.
Perfect! Thanks
JD0x0
Post by JD0x0 »
I recently did my amp with 22n, 22n, 15n polyesters (they were small enough to fit fine)
Trem works at all speeds and sounds better than stock, IMO.
Bombacaototal
beasleybodyshop wrote: Wed Oct 22, 2014 3:03 am
sluckey wrote:The oscillator triode. Cathode is 2.7K/25µF.
Oh. Well dang. I picked the other one. It sounds great. Swapping in the .02s and installing the cathode LED really sounds great. Thanks everyone!
I just wanted to report back on this. I had reduced the LFO speed with 3x .02uF and a red led on the cathode. The tremolo was too fast (I mean super fast like you couldn't hear the effect at all), because of the LED.
I brought back to stock and then had no issues. Anyone else experienced the same?
I have 4 slightly different tremolo circuits with a LED in them. They all work fine. I installed a LED backwards once. It glowed steady at about half brightness and no trem. When I installed it correctly still had no trem. Replacing with a fresh LED fixed the problem. Maybe you had the LED installed backwards?
Bombacaototal
sluckey wrote: Fri Dec 21, 2018 5:26 pm I have 4 slightly different tremolo circuits with a LED in them. They all work fine. I installed a LED backwards once. It glowed steady at about half brightness and no trem. When I installed it correctly still had no trem. Replacing with a fresh LED fixed the problem. Maybe you had the LED installed backwards?
Thanks for the reply. Below was mine before I removed it. Is there any marking on the LED to indicate the side. Adding a 22uF (+) cap across the led helped to tame the speed a fair bit, but I ended up with the resistor as a stock Blackface
Looks like your LED was installed backwards. The flat side of the LED is the cathode and must be connected to ground. Don't use a cap across the LED!
That LED is probably destroyed now, so if you want to use a LED, get a new one and observe polarity when you solder it in. When installed correctly you will see the LED flash at the speed of the tremolo. I usually mount the LED in a bezel and install on the front panel just for eye candy.
Bombacaototal
sluckey wrote: Sat Dec 22, 2018 11:50 am
Ah that explains it! Complete oversight at my end. Do you have any brand preference for the LED as I will have to get a new one anyway
It is a cool idea to have it at the front panel too
Reeltarded
Post by Reeltarded »
Bombacaototal wrote: Sat Dec 22, 2018 4:30 pm
Just buy a pack of anything. A red one is a red one. :)
Bombacaototal
Haha ok!
Reeltarded wrote: Sat Dec 22, 2018 5:03 pmJust buy a pack of anything. A red one is a red one. :)
IMO, some types have a great deal of clarity, while others are more diffused.
Bombacaototal
Reeltarded
martin manning wrote: Sat Dec 22, 2018 5:59 pm
Because you are superman.
Bombacaototal
I added the new RED LED and it works like a charm. I also removed the polirized cap. Thanks everyone for the help
One thing I still need to check a bit better (with more time) is a weird ticking sound. I have the .02uF cap accross the opto (roach) to ground as indicated here to prevent it, but seems not to have been enough: https://robrobinette.com/AB763_Modifications.htm
Bombacaototal
Ok, so back at the ticking issue.
The issue:
Overall the trem works fine. There is no ticking when I am not playing. There is a bit of ticking which replicates the speed pot on some notes only, usually more towards the higher registry than lower.
This is how my circuit is structured:
1) LFO with .02uF as the 3 caps
2) red led at the cathode on the triode of the speed
3) .02uF from the 10M to ground next to the roach
Troubleshooting:
1) I’ve tried replacing the .02uF from the 10M to .05uF and made the ticking worst
2) I’ve tried adding a .02uF across the 100K plate (in parallel) like Dumble did in one of his ultraphonix bandmaster and it made it worst
Not really sure what to do next. Any ideas?
