Airbrake Files
Re: Airbrake Files
I made one of these. I would want to have more attenuation. I have a spare 50 OHM 100 watt resistor that I want to use. Can someone with experience tell me where i should put this one on the circuit! Any suggestion is appreciated.
https://imgur.com/aomu4A8
Re: Airbrake Files
Moved to this forum, it's not a trainwreck, although they're often used with them.
Re: Airbrake Files
I would expect to find this in the Trainwreck Files section. Airbrake attenuators were made and sold by KF’s company, Trainwreck Curcuits.
Re: Airbrake Files
Can anyone explain the calculations of IL and Pout from the Attenuator III file in the original post? Should be simple but there's something i'm missing in my own calculations.
Re: Airbrake Files
Like this:
Last edited by martin manning on Mon Jul 13, 2020 7:17 pm, edited 1 time in total.
Re: Airbrake Files
MUCH APPRECIATED!!!
Re: Airbrake Files
np. Fixed a typo in the text equation for VT.
Re: Airbrake Files
Good morning. I have a question about the adjustable 100W resistors for the Airbrake III. at the beginning of this thread there are both a scheme and layout attached. The layout shows to set terminals on R2 at 6 Ohms, 11 Ohms, and 16 Ohms. whereas the scheme shows resistance values 4, 5, 10, and 6. Can someone explain this? Thanks.
- Littlewyan
Re: Airbrake Files
4, 5, 10 and 6 are the resistances between the lugs on the resistor. I would be wary of that design though as I don't think it could handle a cranked 50W amp. Also it won't sound as good as the original Airbrake design.
The original design, although it presents a higher than normal load to the amp, also keeps a bit of a the relationship between an amp and speaker. A speaker's impedance is not constant, it varies with frequency and the Airbrake presents 'some' of this to the amp. That's why the original design sounds pretty good. So you can modify the design to keep it at a fairly constant 8ohm load, but it will sound very flat. Hope that makes sense.
Re: Airbrake Files
Thanks. Yesterday, I built per the scheme, and it works, but degrades tone a little as attenuation is increased. I’m wondering if I can reuse some of the parts to build the “M” or “M2” attenuator on the Marshall forums. I’m still reading that long forum thread. Not sure if the “M2” is improved over “M” or just different.
Thanks again for your response.
- Littlewyan
Re: Airbrake Files
M2 is an improved version.
Did you build the original Airbrake or Airbrake III?
Re: Airbrake Files
Airbrake III. I had built it prior to your response.
- Littlewyan
Re: Airbrake Files
How much attenuation do you need? As you could try making R1 25Ohm on every setting, which will allow the amp to see more of the impedance curve of the speaker. Should give you back a bit more 'feel'.
Re: Airbrake Files
Thanks. I’m thinking for regular jamming in rehearsal type situations that 6 to 9DB attenuation would be all I would need. However, for night time practice, I would like to have double that available to me.
So if I’m understanding correctly, to modify what I have to what you suggested, I would need to:
Clear switch terminals 8 through 12
Jump terminals 8 through 12 to terminal 7
Is that correct? Any idea on what I can expect for the maximum amount of attenuation in this configuration?
Also, have you built the M2? I’m wondering if I should just change focus and get busy building that. It seems like everyone is pretty happy with that
