High-plate Skyline build
ijedouglas
Post by ijedouglas »
I've been toying with the idea of building this amp with a 5-piece chassis and finally pulled the trigger. The chassis (19x7.25x2.5) and board dimensions were taken from an actual specimen and it is a lot smaller than the other chassis I have worked with. HAD built some spectacular amps but what has really impressed me with this build is how the hell a big guy worked in such a small chassis with such artistry and perfection. The other thing that really stood out for me was his attention to detail with his grounds.
Front/back panel: 2.5 in aluminum c-channel
Bottom panel: 19 x 7 1/8 in aluminum
Sides: red oak: 1/2 in
Ian
dbharris
Re: High-plate Skyline build
Post by dbharris »
Incredible work as always Ian. Looks fantastic!
-Dan
erwin_ve
Post by erwin_ve »
Beautiful work Ian. Looks a lot like the #18x series with the wood sides.
Is the fet side covered with aluminum?
What kind of anchor nuts are u using?
Erwin
ChopSauce
Post by ChopSauce »
That's really cool!
bepone
Post by bepone »
how my metal work shops around get closed , and it is difficult to make something custom,
i was thinkig the same! it is back to the roots actually, and fully DIY! :mrgreen: no need for some bending machines or some workshop , where you are waiting for few months for something, it is ready immediately.. and easy to make holes on cnc nad then screw all together
i think next build i will go this route :wink:
Stephen1966
Post by Stephen1966 »
bepone wrote: Sat Jul 29, 2023 8:28 am how my metal work shops around get closed , and it is difficult to make something custom,
This is all handmade.
Stephen
www.primatone.eu
ijedouglas
erwin_ve wrote: Sat Jul 29, 2023 5:39 am Beautiful work Ian. Looks a lot like the #18x series with the wood sides.
Erwin
Thanks Erwin. Yeah, its a mid #017X amp. I used aluminium flashing for the FET side and the anchor studs are actually 4-40 into an aluminium threaded spacer.
Ian
ijedouglas
If you have access to a CNC this should be a lot easier. I drilled, cut and filed by hand and it was a hell of a lot of work but well worth it. I'm not sure if HAD used a CNC, looking at a few of the amps from that era, I suspect he took the same route as I did.
Ian
timrobertson100
Post by timrobertson100 »
Beautiful work. How did you do the white lettering please, Ian? It has come out very sharp.
ijedouglas
timrobertson100 wrote: Sun Jul 30, 2023 3:28 am Beautiful work. How did you do the white lettering please, Ian? It has come out very sharp.
Thank you. I have a vinyl cutter and it does a great job. Sprayed with black gloss Krylon, applied lettering and then hit it with Krylon clear gloss. As I learned, make sure to leave at least 24 hrs. between coats. 3 failed attempts later and I finally learned the art of patience....
Ian
ChopSauce
Post by ChopSauce »
ijedouglas wrote: Sat Jul 29, 2023 11:01 pmI drilled, cut and filed by hand and it was a hell of a lot of work but well worth it. I'm not sure if HAD used a CNC, looking at a few of the amps from that era, I suspect he took the same route as I did.
You did it by hand ?!.
I was convinced that you had a CNC milling machine. That is great work you did on that chassis ... 8)
bepone
Post by bepone »
my friend has but then it is not possible to bend properly aluminium sheets 2mm,
so i was thinking this route, front+back plates, and top sheet, square holes for IEC sockets, proper speaker jacks holes (11.5mm-12mm) to not to make short circuit with chassis like some of Neutrik connectors doing with metal ferrule... and tube sockets, and half million other small holes.. via CNC..and assebly this way at home easilly..
i think HAD ordered externally build chassis/metal works, this is a lot of work for one person, at least 3-4 different proffesions (from metal, electronic, wood, tolex etc), to be made proffessional as it should...what we need to do all alone often in DIY world :P
ijedouglas
bepone wrote: Sun Jul 30, 2023 7:42 am i think HAD ordered externally build chassis/metal works, this is a lot of work for one person, at least 3-4 different proffesions (from metal, electronic, wood, tolex etc), to be made proffessional as it should...what we need to do all alone often in DIY world :P
From what I understand, HAD built these 5-piece chassis himself as well as all the chassis and speaker cabs. I know at a later stage Kerry Wright built some of the speaker cabs for him and the later chassis look to be ordered from a metal shop.
A jigsaw, file, drill-press and hole-cutters will get you there :D
Ian
ijedouglas
A little more progress
Ian
Reeltarded
Post by Reeltarded »
His perfection? How do YOU do THAT!?
Stunning!
